KONI yellows and ground controls LAST QUESTION for these. PLEASE HELP. no Orings or yes? Page 2
Login | |
RE: KONI yellows and ground controls help needed before... - 5/5/2008 10:21:00 PM
mxs
You shouldn't need the silver spring perches, everything should fit snugly right on the shock body like THIS. You're going to have to cut your dust boots down, and bore the hole out for it to fit over the Koni shaft. Also cut your bump stops if you haven't already.
_____________________________
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3. DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
RE: KONI yellows and ground controls help needed before... - 5/5/2008 11:41:04 PM
arust45
Those look sick!! My koni/gc's should be coming on wednesday for a thursday/friday install along with energy suspension bushings. Buy them off honda-tech? What dampening specs?
97 Civic Ex Rebuilt and blueprinted d16y8 Vitara/Eagle 7.8:1 Comp Oem gasket, ARP headstuds 4puck sprung, lightened flywheel T3 .50A/R, RC440's 18psi tuned on 91 Koni, ground control, 16" SI's 2.5" turboback, Cat delete.
RE: KONI yellows and ground controls help needed before... - 5/6/2008 2:35:07 AM
addiction2bass
so the GCs just use the rubber sleeve and orings to hold it above the clip? i just dont see how that could really hold the coilovers inplace....
99 civic ex, being redone. KONI yellows, Ground Control adjustable coilovers, for starters
RE: KONI yellows and ground controls help needed before... - 5/6/2008 6:05:19 AM
mxs
If it's not fitting correctly then you probably don't have the right sleeves. The Koni/Bilstein sleeves are different.
RE: KONI yellows and ground controls help needed before... - 5/6/2008 2:56:48 PM
addiction2bass
ya mine came off a stock strut setup... so do i have to call and order the correct mount or something? kinda hard to see your pictures where the struts meet the coilover... looks like there is the same thick rubber sleeve... i think its to late to call GC today. guess ill have to call them tomorow and see what they say i should need.. and if i can get fast shiping or not.LOL i hate having most the parts and just short of instaling :( couldnt i just put the stock perches on the KONIs and put them on that way? i hope the coilovers arent completly different!!!!
< Message edited by addiction2bass -- 5/6/2008 3:54:07 PM >
RE: KONI yellows and ground controls help needed before... - 5/7/2008 12:37:56 PM
addiction2bass
well CRAP.... ya they said i have to buy new red shafts to fit the konis....and i didnt know that when i ordered the other parts... (homer) DOOOOOOOPPPEE!!!!!!!!!!!! another 108bucks adding up DAM that sucks!!!! o well i guess.... now i didnt get such a good deal on the used Ground controls :( o well i guess if i ever have strut problems i can slap the GCs on the stock struts with the red sleeves for a temp fix if i ever do have a problem :( ended up costing me another 30bucks more than it would have cost to buy brand new. but guess this way i have spare shafts and a perch and orings that i probably wont need now :( and hopefully ill get a tracking number this time... he had my email entered in there wrong i guess... maybe ill get it before this weekend and maybe not..... most likely NOT with all my luck lately!
