Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
converting an auto ecu to manual???
  Printable Version
Honda Civic Forum >> Your Ride >> ECU Tuning & Fuel Management >> converting an auto ecu to manual??? Page: [1]
Login
Message << Older Topic   Newer Topic >>
converting an auto ecu to manual??? - 5/6/2008 10:29:23 AM
panaphobic
Status: offline
i found a quick write up on this, but it didn't help me really. i did a bunch of other searching and can't find any useful info.
i bought a p28 ecu, but me being stupid didn't think to check the serial number on it. happens to be an automatic ecu. i have a standard and i just did a mini-me swap, and i believe that this is my problem.
does anyone know exactly how to convert the automatic ecu to a standard ecu???
the write up i found has this info. it was "borrowed" from hondata........
"How to convert an automatic ECU to 5 speed specs
First, let's find out if we have an automatic, or a 5 speed ECU. If you don't want to plug it in and throw code 19 (automatic trans lockup solenoid) to find out it is an automatic ECU, then look at the code on the side. If the second to last number is a 5, then you have an automatic ECU (for OBD-1 USDM ECUs). If the 2nd to last # is anything but a five you have an ECU for a 5 speed. If you have a jdm obd-1 ecu, look at the last 3 digits: 900 or 901 will be an automatic. If you were unfortunate enough to get an automatic ECU, then read on and learn how to cure all your problems.
The following information was all obtained from Hondata.com and the picture was graciously borrowed from them as well.
For Jdm Pr3/Pw0 ECUs:
Move the jumper from R68 to R67 (both locations are to the left of the ROM)
For USDM OBD1 ECUs (p28):
Underneath the ROM there is a row of resistors labelled with RP__ . Remove RP17 and install a jumper across RP18.
For JDM OBD1 ECUs:
RP18 (in the same location as usdm) needs to be lowered in value from 2.4k to 1.4k ohms"
problem is that i have a jumpers on BOTH RP17 AND RP18.
this is my ecu (sorry for the bad pic, it's the best i can get right now....)
has anyone done this before????? what do i do? and please don't say "get a different ecu."
any help would be greatly appreciated!!!!
Post #: 1
RE: converting an auto ecu to manual??? - 5/6/2008 11:51:52 AM
danomatic93
Status: online
danomatic93's photo gallery
Look at the Auto/Maunal section...
This is one I did 2 weeks ago...
Desolder the resistors RP17 and RP18.
Then, solder a jumper across RP18.
Done.
If that doesn't make sense to you, have someone else do it for you!!!
A jumper is simply a wire (0 ohm resistor, thus no resistance).
< Message edited by danomatic93 -- 5/6/2008 12:05:31 PM >
_____________________________
Build Thread: http://www.hondacivicforum.com/m_576697/tm.htm
For Sale Thread: http://www.hondacivicforum.com/m_558867/mpage_1/key_/tm.htm#559090
Bob Saget!
(in reply to panaphobic)
Post #: 2
RE: converting an auto ecu to manual??? - 5/6/2008 12:13:41 PM
panaphobic
Status: offline
i thought they meant to put a resistor in for RP18. i understand what you mean though. thanks for the pic and the quick response. i really, really appreciate it!!!
(in reply to danomatic93)
Post #: 3
RE: converting an auto ecu to manual??? - 5/6/2008 12:21:15 PM
panaphobic
Status: offline
oh i forgot to ask, do you have to remove any else?
Post #: 4
RE: converting an auto ecu to manual??? - 5/6/2008 12:24:44 PM
danomatic93
Status: online
You don't need to, but you can also remove the Auto transistors IC15 and IC16
< Message edited by danomatic93 -- 5/6/2008 12:32:06 PM >
Bob Saget!
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic >> Your Ride >> ECU Tuning & Fuel Management
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414244
remmy11161
fiirkan10515
mill$civic8471
marty8273
mxs8006
fliphkd7207714
nail i3unny7705
sacicons7675
addiction2ba7375
New Vendors
K&N Engineering, Inc.
