90 crx si tranny problem. clutch is out, but car won't go anywhere!!!! please help!
Login | |
90 crx si tranny problem. clutch is out, but car won't ... - 5/8/2008 10:42:09 AM
panaphobic
well, finally after weeks of trying to get the crx running, i finally did. so i dropped the front end back on the ground for the first time in a month and threw the plates on and took her for a spin! i went down the road, then back up the next road over, then when i pulled out onto the main street, i shifted from 1st into 2nd and then something happened, or well didn't i guess would be more accurate. something, either the clutch went out, or the tranny is shot, or something else happened. and when i released the clutch after i put it into 2nd, nothing happened. gas it gas and it just rev-ed up, like it was in neutral. i put it back into 1st and the same thing happened. the engine just rev-ed. now, i don't know much about tranny's and clutches at all. so i need some opinions. today, i jacked the front end up and started the car. put it in gear and the tires didn't spin. i kept dropping the clutch a few times and it didn't do anything. with the car still running, i when and checked the clutch cable (it's not a hydraulic tranny) to make sure it was still attached and it was and then i went to go turn the crx off when i noticed the wheels were spinning. so i shifted the gears into 2nd and 3rd and 4th and the wheels kept spinning faster and faster. so i dropped the front end again and i put it back into 1st and let the clutch out. it didn't move anywhere. you could hear a grinding sound though when the clutch was out. it sounded just like disc brakes that were rusted. but i wasn't moving anywhere so it couldn't be them. last night though when i drove it down the road and back, the clutch didn't slip one bit. it felt just like a new clutch. the clutch still feels stiff like it was before. not loose or anything. the clutch didn't bite at the end of the pedal or anything. it was pretty much right in the middle, like most cars are. you can feel and hear the tranny shift into each gear too. so i just don't have any ideas on what it could be. if anyone out there has any ideas, let me know! one of my friends said it might have something to do with the throw out bearing. but let me know what you think. i just don't want to have to end up buying a bunch of parts that i don't need. hopefully this weekend (weather permitting) i'll see about getting under the car and taking a look at it. possibly dropping the tranny to if need be. i read an FAQ and it sounds like it might be the input shaft bearing. but again, i don't know. does anyone know if/where a write-up on how to change it is? (if not, and this is the problem, i'll see if i can do a write-up on it if i have to replace it.) or if it's possibly something else, what do you think it is and could you post a link to a write-up on it if you know where one is. i really appreciate the help that i've been getting from here lately for everything i've been having trouble with so thanks guys!!!
RE: 90 crx si tranny problem. clutch is out, but car wo... - 5/8/2008 11:30:30 AM
OLD n TIRED
What had you been working on while the car was in the air? Did you have the axle shafts out of the transmission? If so would it be possible for them not to be seated back in place? Just a train of thought.
RE: 90 crx si tranny problem. clutch is out, but car wo... - 5/8/2008 11:47:21 AM
panaphobic
i was doing a mini-me swap. and i had a bunch of problems with it. but i only had it in the air cuz i had to take the drivers side wheel off to get the crankshaft pulley off and to do the timing. i bought the car with a blown head, and i don't know how long it had been sitting before i got it. it was garaged though. i didn't touch anything on the tranny or driveshafts.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
