d16 turbo
Login | |
d16 turbo - 5/8/2008 6:01:39 PM
abdoo
i have a honda civic hatch si... some of my friends tell me if i put a turbo on i will more than likly blow my engine if i dont ungrade my pistons and conecting rods is this true?
RE: d16 turbo - 5/9/2008 12:21:51 AM
Live_4it
depends on how much you plan on boosting.
_____________________________
RE: d16 turbo - 5/9/2008 12:29:55 AM
arust45
Your friends are smart. If you turbo your motor with your current knowledge of supercharching, you will blow your motor, research.
97 Civic Ex Rebuilt and blueprinted d16y8 Vitara/Eagle 7.8:1 Comp Oem gasket, ARP headstuds 4puck sprung, lightened flywheel T3 .50A/R, RC440's 18psi tuned on 91 Koni, ground control, 16" SI's 2.5" turboback, Cat delete.
RE: d16 turbo - 5/9/2008 5:41:04 PM
abdoo
i have been researching it but i was wondering with a small enough boost i can servive. lol
RE: d16 turbo - 5/9/2008 9:51:18 PM
trustdestruction
Do a compression check first. If everything checks out, and your motor runs well, it should be able to handle 6-8 lbs of boost.
'93 Civic Del Sol Si AEM sri Megan Racing 4-2-1 Header Magnaflow Hi-flow Cat Apex-i WS2 Catback KYB AGX Shocks/Struts H&R Springs Strut Bars Sony xPlod Headunit/Speakers Profile 700W Amp MA Audio 10" Subs
RE: d16 turbo - 5/10/2008 12:43:06 AM
arust45
Your pistons and connecting rods can most likely can handle 6-8lbs on a small turbo, but it is enough boost to lift your head and blow the headgasket even on the healthiest of engines. If your engine is in good condition after compression/leakdown testing, order yourself arp headstuds and a headgasket from your nearest honda dealer before boosting. Look into a t3, t25, or equivalent sized turbo, well suited for the size of your motor. You'll also need a high performance clutch, because the stock clutch will wear down to nothing fast. Good luck on your research.
RE: d16 turbo - 5/11/2008 1:22:55 AM
didder
t25 turbo is going to be a torquier turbo setup which will be harder on your rods. and it will have a lot less top end power, but it will be a pretty fun dd'er t3/t4 turbo is more suitable imo, boosts around 3600rpm and will net you around 200+whp safely with 8lbs of boost and a good tune. headstuds arent a nescessity below 220whp, but always the safe bet, plus there easy to install. hell, sov has his ek coupe boosted to 220whp on 8lbs for 6 months on a bone stock d16y8, and his head never lifted, you ""should"" be fine as long as your compression checks out, id say keep the numbers within 5-7% for 8 pounds
