Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Lowering 2"-Camber Kit Needed?
  Printable Version
Honda Civic >> Your Ride >> Suspension, Brakes, Tires & Wheels >> Lowering 2"-Camber Kit Needed? Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
Lowering 2"-Camber Kit Needed? - 5/9/2008 8:11:24 AM
BuckHijo
Status: offline
Ok so, I am getting a set of Skunk 2 coilovers with KYB GR2 struts to lower my civic 2" at the most. My question is, would it be a good idea to get a front and rear camber kit? This is the kit that I am looking at. Also, is it possible to adjust the stock set up so I don't have to get a camber kit? A family member owns a car repair shop and has all the machines and knowledge. Thanks for any help.
< Message edited by BuckHijo -- 5/9/2008 8:20:29 AM >
Post #: 1
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 8:20:05 AM
ej6buddy
Status: offline
ej6buddy's photo gallery
unfortunately, civics aren't very much fun when it comes to alignments, and with a 2 in drop, yes, you'll need a camber kit (from a reputable company).  and the link you showed me are the skunk2 components, those are very good quality and i'd recommend getting them and getting an alignment directly after the installation.
_____________________________
(in reply to BuckHijo)
Post #: 2
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 8:26:31 AM
BuckHijo
Status: offline
Sounds good, I'll get the camber kit I linked to and have install them when I install the coilovers and struts and do an alignment all at the same time. Is there anything else I am going to need for lower my car?
(in reply to ej6buddy)
Post #: 3
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 8:41:00 AM
BuckHijo
Status: offline
Also is this going to be a good set up for lowering my car? The Skunk 2 coilovers with KYB GR2 struts (maybe Tokico HP struts). With the Skunk camber kit?
Post #: 4
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 9:05:03 AM
My04Civic
Status: offline
My04Civic's photo gallery
umm, let your springs settle a few days before getting an alignment
2004 Honda Civic EX Coupe - I/H/E, Tokico Struts, springs
Forty4U2BNVS: I get my cardio from beating my bag
Surf Wagon1994: yeah james i got anal this weekend
Post #: 5
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 10:04:41 AM
BuckHijo
Status: offline
quote:
ORIGINAL: My04Civic
Thanks for the heads up.
(in reply to My04Civic)
Post #: 6
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 11:56:09 AM
reaper2022
Status: offline
reaper2022's photo gallery
Umm... I'm going to say you don't need a camber kit.  If you get it aligned and have the toe set back to factory, you won't kill your tires (take a few hundred miles off the tire life, maybe... but not as much as everyone would have you believe).  My car is dropped about 2.5" in front and 3.5" in back... I'm tucking tires all around.
Last summer I didn't bother with an alignment; after about a month, you could see the inside of the tire was wearing from the toe.  It took all of about 3 months to wear my fronts down to the cords.  When I took the wheels off, you could tell it was toe wear; sure, it was mostly on the inside of the tire, but it was feathered.  Camber wear takes the tread down evenly on the inside of the tire; toe does not.
This spring when I dropped my car (March), I got an alignment within a week.  I don't have any tire wear so far (also, I'm running the tire pressure about 3psi lower to even out any tire wear).  I have about 3* of negative camber.
If you want to be super-cautious, or if you hate the look of negative camber (and assuming you have an extra $300 sitting around), go for the camber kit.  If you don't want to spend money on parts you don't absolutely need, skip it.  Just remember to get it aligned!
My car - for sale!
Post #: 7
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 12:07:19 PM
addiction2bass
Status: offline
addiction2bass's photo gallery
quote:
ORIGINAL: reaper2022
X2 not to important for camber kit.... the rear you can just slap 2-3washers under the upper arm and it will be fine....
with my old Stech springs on my 99 the front had the passenger side camber SLIGHTLY OFF but not to bad. only like 0.1 out of specs....... and my rear was fine with just 3 washers behind each bolt on the upper arms. tho its also a good idea to get slightly longer bolts..............
it wont wear your tires hardly any... more less looks for you.....
99 civic ex, being redone.
KONI yellows, Ground Control adjustable coilovers, for starters
(in reply to reaper2022)
Post #: 8
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 1:13:00 PM
BuckHijo
Status: offline
Thanks for all the info. I think I'll lower it about 2" then get it aligned, probably do the washer trick on the rear, and then see how it does after a few months. Plus it'll save me 300 bucks, that makes me happy lol. I'm sure my mechanic (father in-law) will know how to align it good, we call him Mr. Magic Man, a true genies with imports .
(in reply to addiction2bass)
Post #: 9
RE: Lowering 2"-Camber Kit Needed? - 5/9/2008 1:43:49 PM
croninc
Status: offline
yea i was going to say you wouldnt need it too, just depends what size rims you got an how low you really want to go and 2inch shouldnt be that big of a deal
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic Forum >> Your Ride >> Suspension, Brakes, Tires & Wheels
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10321
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
