Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
painting my interior
  Printable Version
Honda Civic Forums >> Your Ride >> Appearance >> painting my interior Page: [1]
Login
Message << Older Topic   Newer Topic >>
painting my interior - 5/11/2008 8:09:45 PM
PhillipBurch
Status: offline
PhillipBurch's photo gallery
I'm wanting to paint some interior pieces in my car, but I'm not sure what kind of paint I am supposed to use.
Also, I'm wondering how you take out the center bezel that holds the stereo and heater controls and stuff.
_____________________________
AEM sri, 421 header, FULL Pioneer sound system, 20% Tint
http://www.cardomain.com/ride/2642792
Post #: 1
RE: painting my interior - 5/11/2008 9:15:39 PM
danomatic93
Status: online
danomatic93's photo gallery
In general used paint for the plastic pieces (I suggest krylon fusion plastic paint) and VHT black vinyl dye for the vinyl parts.
Here's a my thread that relates: http://www.hondacivicforum.com/m_452077/tm.htm
Build Thread: http://www.hondacivicforum.com/m_576697/tm.htm
For Sale Thread: http://www.hondacivicforum.com/m_558867/mpage_1/key_/tm.htm#559090
Bob Saget!
(in reply to PhillipBurch)
Post #: 2
RE: painting my interior - 5/11/2008 10:25:57 PM
Vilex
Status: offline
Vilex's photo gallery
quote:
ORIGINAL: PhillipBurch
Well, I use Duplicolor products. And usually 800 grit wetsandpaper. I don't know what year or anything your car is, so I can't help you there.
But what I usually do to paint stuff.. Or what I did to paint my plastic valve cover (D17).
Step 1) Clean the piece you are going to paint with some rubbing alcohol or something to get all the oils and stuff removed so the paint will stick better.
Step 2) Use the 800 Grit wetsand paper and sand the plastic down to make it smoother (It makes it smooth, and the finish product will turn out alot nicer)
Step 3) Spray on a couple light coats of the primer. Be sure to get everything coated good, or the paint wont stick right and will probably chip off easily. Allow to dry.
Step 4) Now spray on the color of your choice. Make sure you use several light coats, not one heavy coat to, avoid runs. Follow the instructions on the paint can to achieve the best results. Allow to dry thoroughly.
Step 5) Apply a few coats of clear coat spray paint, to add a high shine and to add extra durability.
Now.. I use Duplicolor products, but thats just a personal preferance. Thats a general guide. An extra step(optional) that I do is.. Sand, primer, sand, paint, sand, paint, clear. You don't NEED to do that.. But I feel it makes the paint stick a little better, and have a better outcome, but thats just my little personal preferance. And, I usually put 3 coats of primer on, 3~4 coats of paint (Depends on how you like it), and usually 3~4(Depends on how shiny you want it, but I usually go with 3)
I hope this helps, if you have any questions. Feel free to ask.
Post #: 3
RE: painting my interior - 5/11/2008 10:52:23 PM
sir_bobos
Status: offline
It looks like you have an EK. To remove the central controls use a screwdriver to pry out the tabs around the sides, there's one in the center of each side, then it should slide right out. If that didn't make sense let me know, I can take some pics later when it gets light.
EDIT* Also pry out the things that hold the defrost button and the emergency light button. there are screws behind that.
< Message edited by sir_bobos -- 5/12/2008 8:23:28 PM >
(in reply to Vilex)
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414235
remmy11161
fiirkan10506
mill$civic8468
marty8273
mxs8006
fliphkd7207711
nail i3unny7705
sacicons7675
addiction2ba7358
New Vendors
K&N Engineering, Inc.
