Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 05-20-2008, 01:13 PM
enigma34 enigma34 is offline
My Garage
Default RCA cables melting!!
I just installed an amp and sub. It was working fine, then the subs started to thump on its own. Afterchecking everything i unstalled the wires to the amp, and its still thumping, And also my RCA cable's are melting and smoking. What is the problem, it was working fine then all this happends!!!
The RCA cables that came with the amp kit are colors red and black. Im gessing the black means white? But it was working fine so i dont understand!!
__________________
My 1996 Civic HX
http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=120 408167&albumId=1700071
Sponsored Links
Old 05-20-2008, 01:25 PM
mk378 mk378 is offline
My Garage
Default RE: RCA cables melting!!
Your amplifier is not properly grounded. The current is flowing thru the RCA cables and the head unit ground instead.
You can use any color wires you like as long as you keep left and right right.
Old 05-20-2008, 01:29 PM
My Garage
Quote:
ORIGINAL: mk378
where is a good place to ground it? its on the spare tire mount.
__________________
My 1996 Civic HX
Old 05-20-2008, 01:50 PM
My Garage
Is it ok to remove one of them bolts that are at the end of the trunk under the carpet? Will that be a good ground??
__________________
My 1996 Civic HX
Old 05-20-2008, 02:25 PM
addiction2bass addiction2bass is offline
My Garage
a decent pre existing bolt is the rear bumper brace. they are on the left and right side of the trunk 2 bolts going straight down.... just remove 1 bolt and use a wire brush and clean the metal around the bolt and then ground it there! with the factory bolt.
but now that your rcas are melted id say you should replace them! damage could be done internaly and shorting the wires...... and hopefully it didnt mess up your radios rca outputs!
DO SOME READING MAN.....
http://www.bcae1.com/
__________________
Old 05-20-2008, 03:22 PM
My Garage
i have the bolt out, but my ring terminal is to samll to fit the bolt.. So what are my options? Is the only option i have is to buy a biger ring terminal?
__________________
My 1996 Civic HX
Old 05-20-2008, 03:27 PM
My Garage
im going to radio shack, its like 5 miles down the road, i hope they have ring terminals
__________________
My 1996 Civic HX
Old 05-20-2008, 03:34 PM
My Garage
that or just file the opening alitle larger....
__________________
Old 05-20-2008, 04:27 PM
My Garage
I went to radio shack, and bought a box with all that stuff for eletrical work n stuff. it came with like 4 size rings. onewas biger than what i had at home so i thoght it would fit..... i get home and, nope still need a lil bigger!!!this has been nothing but problems, one thing to the next... will it till work if i cut the ring and wrap it around and tightin the bolt over it?
When i was there i also bought wire cuters..lol now i buy them after i have dodne the job, using my teeth....
__________________
My 1996 Civic HX
Old 05-20-2008, 05:32 PM
My Garage
i have it hookt up and its working!! i can only use it on one channel, i think its hpf. if i have it on the other two channels, it looks like the subs are breathing. they will suck in then out, not making a loud thump like befor, but doing wierd things. I dont have the gain to high but high enuff to get that nice bass. So its working now, so it should not blow the amp or what not?...hhhhh
__________________
My 1996 Civic HX
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
