Ok,these are all the parts I have left over from the 98 honda civic ex 2door, listed below. If its not listed as sold, that means i still have it.You can email me at
h22a4typer@sbcglobal.net, or pm me, or call me at 1626 466 7563. and I will also ship items,and paypal verified....thanks for looking.ALL PARTS ARE OEM.
K-SPORT 36 WAY ADJUSTABLE COIL OVERS. ALL 3 ARE GOOD 1 IS BENT.
SKUNK2 - LOWER REAR SWAY BAR. SOLD
INNOVATIVE MOTOR MOUNT KIT IN BLACK. SOLD
HOOD- ( IN WHITE COLOR, OEM,,CLEAN NO DENTS.). SOLD
FRONT BUMPER COVER. (BLACK COLOR, WILL NEED REPAINTING,PAINT PEELING. SOLD
DRIVERSIDE KNUCKLE ASSEMBLY.
PASSENGERSIDE KNUCKLE ASSEMBLY.
PASSENGERSIDE REAR KNUCKLE ASSEMBLY.
V-TEC SOLENOID.
V-TEC PRESSURE SWITCH.
FRONT SEATS. SOLD
REAR SEATS.
SEAT BELT BUCKLES.
DASHBOARD.
TRUNK LID. SOLD
HEADLIGHTS.
DRIVER AND PASSENGER SIDE BUMPER FILLER PIECES BELOW THE TAIL LIGHTS.SOLD PASSENGERSIDE.
PASSENGERSIDE OUTER TAIL LIGHT.
BOTH INNER TAIL LIGHTS.
CARPET.
SUNROOF ASSEMBLY.
SUNROOF LID COVER.
DRIVER AND PASSENGER SIDE "A " PILLAR COVERS.
SHIFT LINKAGE.
WIPER ARM BLADES.
WIPER MOTOR ASSEMBLY.
REAR WINDOW GLASS.
PASSENGER DOOR PANEL.
DRIVERSIDE DOOR POWER MIRROR.
A/C DRIER.
A/C EVAPORATOR UNIT.
HEATER CORE.
FAN BL0WER.
DRIVERSIDE SKIRT.
TRUNK CARPET.SIDE CARPET.
TRUNK CARDBOARD.
DOME LIGHT.
DRIVERSIDE DOOR SILL COVER.
PASSENGER DOOR SILL COVER.
DRIVERSIDE WINDOW MOTOR.
DRIVERSIDE KICK PANEL.
ECU KICK PANEL COVER.
STEERING WHEEL.
HEADLIGHTS/BLINKER COMBO SWITCH.
GLOVE BOX.
BRAKE BOOSTER.AND MASTER CYLINDER.
SLAVE CYLINDER. SOLD
CLUTCH COVERSION HARD LINE. SOLD
CLUTCH,BRAKE,GAS PEDALS. SOLD
STOCK AIR INTAKE AIR BOX.
CHARCOAL CANISTER.
FRONT BUMPER GRILL.SOLD HAVE EXTRA IN WHITE COLOR
POWERSTEERING PUMP HARD LINE.
FRONT DOOR SPEAKER COVER LID.
CLUSTER TRIM BEZEL.
LOWER STEERING COLUMN FUSE COVER LID.
CENTER SHIFTER CONSOLE.
PLASTIC COVER WHERE THE LIGHTER GOES.
UPPER AND BOTTOM STEERING COLUMN COVERS.
RACK N PINION. SOLD
SUBFRAME. SOLD
CLUTCH AND PRESSURE PLATE. SOLD
