Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 05-21-2008, 08:46 AM
pendletone pendletone is offline
Default D16Y8 engine valve issues...
I'm looking at buying a 96 Honda Civic from an owner who tells me they are having a "floating valve" issue. From what I've seen while the engine is running, it seems very weak and there is a smell of gas coming from the exhaust. The way it was explained to me was that it would take a couple hours to correct this issue.
Does anyone have any thoughts as to correcting this issue?
Ideally what I'm hoping to do is find a manual or a step-by-step breakdown of what I need to do to fix this. I'm no mechanic by any means, so please bare with me for any stupid questions.
Sponsored Links
Old 05-21-2008, 09:07 AM
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
Default RE: D16Y8 engine valve issues...
replacing valves might be easier for you to just take the head off and take it to a machine shop and let them do it. "floating" valves is when the engine has reved higher than factory redline and the valve spring cant keep the valve closed fast enought and then your valve makes slight contact with your pistons bending/breaking them hince lost of compression
__________________
non-vtec ALL THE WAY
cylinder head guru!
Old 05-21-2008, 09:15 AM
Any good place that I could find a manual to get that off then? I'm stranded in Germany with no hope of finding an english version...
Old 05-21-2008, 01:49 PM
ou order like a chilton or haynes? they will tell you how to replace a bent valve
__________________
cylinder head guru!
Old 05-21-2008, 02:51 PM
RonJ RonJ is offline
Quote:
ORIGINAL: pendletone
http://hondatech.info/downloads/Auto/Manuals/Civic/
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/zerothread/1901557
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
