i was looking at the crower stage two turbo grind cam, but it says it requires springs and retainers kit, i just got my head back from the machine shop last week so it should be fine right? would anyone recommend a different cam? thanks
I'd just go with a Stage 2 cam. Usually turbo cams are meant for turbo, unless you have a turbo setup.
But I think for my car, stage 2 cams run $325 and springs and retainers cost another $300.. You could get stage 3, but eh.. I wouldn't recommend it, you have to have engine management and it would have a rough idle since its mainly a drag cam.
I'd say stage 2 is perfect for street applicable.
__________________
<Friend> GOD. I hate macs! Widgets are the dumbest idea ever. <Vilex> Your birth was the dumbest thing ever. OBURN.
Ah, if you're going to boost.. Then by all means, go with the turbo stage 2 cams. And yes, you HAVE to have the springs/retainers. Most aftermarket cams say you need to change the springs and retainers. Changing the springs/retainers is apart of upgrading your valve train, and from what I know.. Its required.
__________________
ok thanks, i wasn't planning on upgrading those but if it will keep the engine from dieing then i'll do it, is this something a shop has to do or is it simplely take off old and put on new, and i'm assuming i can keep my stock valves because as i said they have been worked on and cleaned up and all that
Well.. I'd recommend taking it to a shop. Its not really for the beginner enthusiests. If you can change your own timing belt, tensioner, and water pump, then i'd say you could possibly do it. But I would still recommend a shop, because if they **** up, its on them. But stage 2 cams are a great internal mod. I think you can get anywhere from 18~25hp with them? I'm not exactly sure, but thats my rough estimate.
__________________
Yeah. No problem. I'd say get a Haynes manual for your Honda and tell your dad to give it a shot? If you fail, take it to a shop and let them fix your mistakes lol.
__________________
