Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > EG Swaps
Reply
Old 08-03-2004, 09:59 PM
AnakinKenobe AnakinKenobe is offline
My Garage
Send a message via AIM to AnakinKenobe Send a message via Yahoo to AnakinKenobe
Default 95 Coupe Motor Swap Question
I wanna stick a 99 Si motor in my 95, this is my first attempt at this i understand i will need a harness some mounts and the motor of course anything else i should know or get, how long would this swap take and how hard is it..
__________________
Hold her tight, had her last nite lol haha ....
Sponsored Links
Old 08-03-2004, 11:45 PM
sacicons sacicons is offline
My Garage
Default RE: 95 Coupe Motor Swap Question
where do you live? If you are in california, then smog will be an issue. if not, then you would be better off with a japanese motor. they start with a little more power, and around 30-50k miles, all for less money. As for parts, you will need motor, trans, ecu, axles, mounts, shift linkage, and you should change the timing belt, water pump, and clutch while the motor is out. also, budget in a little more money for little things like hose clamps, hoses, sensors, spark plugs, wires, oil ( for both motor and trans) and other things that will pop up. a bigger radiator is not necessary, but neither is DOHC VTEC. Riiiight.if your car is vtec already, then a lot of work is done for you. the wiring is the hardest part. if you know anyone who is familiar with car audio wiring, enlist their help. All in all, if it goes smoothly, it can be done in a day. Good luck, and enjoy
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 08-05-2004, 06:50 PM
My Garage
what B series motor is inthe 99si ???
__________________
Old 08-05-2004, 10:32 PM
My Garage
B16a2
10.2:1 compression
160HP
111 LB/FT torque
__________________
Quote:
ORIGINAL: Forty04
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
