Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 08-04-2004, 12:08 AM
joshln joshln is offline
My Garage
Default need help for remote wire power
I try to install the new radio, when I unplug it I make a mistake to touch the remote wire to the ground (of radio). By inspection, I knew that the power of that wire is disappear; there was only 3.5 Volt only, its must have 12 V to order to run ( to open the power of radio). I also check all fusses are fine. Does any one know what is happening? I have Civic 93 4 doors .Thaaaank !!
Sponsored Links
Old 08-05-2004, 12:35 AM
JayMan JayMan is offline
My Garage
Default RE: need help for remote wire power
if there was no power to the unit, then technically the remote touching ground shouldnt have done anything, at most a fuse if connected, but those are ok, chek ur wiring, i have had little issues of remote wires only my switch
Old 08-05-2004, 12:52 PM
My Garage
Thank Jayman !
I have the voltage meter, so I turned on the key and check the remote wire from the ignition; there is about 3.5 volt (it must have 12 Volt to order to turn on the radio). I checked all fusses were good. Do you know that beside the fuse, it’s anything wrong with this? Thanks!
I got Civic 93 4 doors
Old 08-15-2004, 09:35 AM
eggie75 eggie75 is offline
My Garage
what did you hook up the remote wire to??? did you buy a harness or just splice the wires?
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
