Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 06-02-2008, 09:37 AM
blackmetal619 blackmetal619 is offline
Default clutch master cylinder
ok so yesterday I changed the slave cylinder no problem, but when I go to do the master cylinder, I cant remove the pin thats holding the screw in. Its on the inside of the car connected to the clutch pedal.
How do you remove this pin?
its such a tight fit back there I cant see which way to pull it out
__________________
Sponsored Links
Old 06-02-2008, 10:43 AM
RonJ RonJ is offline
Default RE: clutch master cylinder
Helpful Hint: Include the year and model of your Civic in your signature.
You must first remove the cotter pin. This information should help:
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/zerothread/1901557
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 06-02-2008, 11:59 AM
thanks, i finally got it.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
