Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 08-04-2004, 11:24 AM
Lab Rat 21 Lab Rat 21 is offline
My Garage
Default turbo problem
i just got my car back from the shop yesterday w/ the turbo installed. when i drive it, coolant shoots out of the radiator resevoir. the temp is a little higher than before the turbo. but even when i drove it out of boost, it still boiled the coolant over. i had my ac components removed but i dont think that should affect cooling. does anyone know what could be going on?
Sponsored Links
Old 08-04-2004, 12:29 PM
polo708 polo708 is offline
My Garage
Send a message via AIM to polo708
Default RE: turbo problem
didnt the shop that installed it say anything? If not then they are giving you some bad service. You probably need a new thermostat. Yours isnt broke, just that the temp. is set too high. With my supercharger (turbo is the same because it runs hotter) I had to get a lower temp thermostat. Check up on that. not too pricey... like $20 maybe?
__________________
-brian
Old 08-04-2004, 02:31 PM
NTX NTX is offline
My Garage
You should just take it back to the shop that installed it and have them check it out.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 08-04-2004, 02:37 PM
My Garage
im going back to the shop after work today. i dont think its the thermostat because i just replaced it a year ago. hopefully i'm just low on coolant.
Old 08-04-2004, 03:54 PM
sacicons sacicons is offline
My Garage
if you use a low temp. thermo, you need to use a low temp fan switch as well. the thermo wont do you any good without a matching fan switch, it will open up @ about 160* instead of 180*, but then the fan kicks on at 180*, so it wont get any lower than 180* under hard use. get a 160* fan switch.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 08-04-2004, 03:58 PM
My Garage
ahh crap... i got so distracted talkin about thermos and fan switchs, that i didnt think it through. get a new radiator cap. might as well go with a high pressure one(Greddy). the one you have is probably not pulling the coolant back into the radiator when it cools, so as it heats up again, it keeps filling the resevoir and overflows it. ive had this problem before and thats how i fixed it.
__________________
Quote:
ORIGINAL: Forty04
Old 08-05-2004, 10:25 AM
My Garage
i have filled up the resevoir and radiator a couple of times before driving it. the temp has been steady and no coolant loss. i guess there were just bubbles in the system. hopefully it stays steady. thanks for the help
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
