Strange CEL
Before I start my story - 2002 Civic DX / ~150k miles / Auto / AEM SRI / Magnaflow catback
Last weekend I was driving home from my parents house and about a mile down the road I pushed on the gas peddle like normal and the car seemed to bog, didn't want to shift, and was acting strange. I've had it once where it wouldn't shift past second and I just pulled over, shut it off and started back up again and it worked, so I tried that... and it seemed to work. About a mile down the road it started up again and my CEL came on. I was low on gas at the time (CEL came on at same time as Low Gas light), so I pulled into the next gas station and put $25 in and started the car back up. Pulled away and about 100yrds down the road the CEL went off and car drove fine.
I drove the car all week with no problems - to and from work (12mi one way) and grocery shopping, etc. Everything seemed to be running fine, so I figured the CEL and bogging engine had something to do with low fuel level. Today I got in and started to work and it started happening again - bogging, not shifting at the right points, etc. so I looked and both Gas Light and CEL were on again. I drove to the nearest AutoZone and had them read the CEL and it was P0122 - TPS - "The PCM has determined that the input from the throttle position sensor is lower than expected for the current engine operating conditions."
I searched on here for TPS and read that it's a $600 replacement from Honda because they replace the whole TB [:@] - or $80 for a new TPS that I could install myself on my current TB. I checked the engine bay and I didn't see anything wrong with the wires or plug, and when I get my hand on a volt meter I will check the middle pin (read it should be between .45 - .50 for idle and 4.45+ for WOT) to make sure everything there is working correctly.
But this leads me to my question.. It seems to only be happening when I am low on gas. I will fill up on my way home today to verify - but like I said it has happened twice when I get to about 1gal left in the tank and stopped when I filled up.
__________________
:: 02 Civic Coupe ::
AEM SRI | Magnaflow 2.25" Catback exhaust | White LED interior | 20% tint all around | Monster iCruze iPod integration | Autoloc CK-2000 Automatic door lock w/ keyless entry
