Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 06-04-2008, 01:51 PM
BAKnBLACK BAKnBLACK is offline
My Garage
Default 99 ex auto to manual swap
this weekend ill be buying everything i need for a full swap and ive heard i have to completely take the engine out for it i wanted to know if this is true also if so wat maintence should i do on the negine while it is out of the car thnx for your suggestions
Sponsored Links
Old 06-20-2008, 02:59 PM
trustdestruction trustdestruction is offline
HCF Sol'er
My Garage
Send a message via AIM to trustdestruction
Default RE: 99 ex auto to manual swap
new throwout bearing
if you got the money put in an aftermarket clutch disc, pressure plate, flywheel, short shifter
Old 06-20-2008, 09:02 PM
SilverSedan SilverSedan is offline
My Garage
+1
If you got everything pulled out, you might as well upgrade drivetrain stuff clutch and bearing, shifter, CV axles (if you're gonna go after big power) things like that... might want to consider swapping out your engine/trans mounts for stiffer ones too.
__________________
97 Sedan D16Y7 5spd...stock
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
