Go Back   HondaCivicForum.com > General Automotive > General Civic Talk
Reply
Old 06-18-2008, 09:51 AM
davew2 davew2 is offline
Default AC, 1998 civic
So my AC cycles on and off a lot, and ive checked the usual stuff. Heres the history and what ive found out so far.
New compressor, refilled by mechanic. Low side reads about 35psi, low side pipe gets cool but not cold. Condensor fan works, relay checks out, AC is better in the morning when its cold out. AC cycles on and off when its really hot out.
Whats the problem??
__________________
Dave
Sponsored Links
Old 06-18-2008, 11:16 AM
mk378 mk378 is offline
Default RE: AC, 1998 civic
The compressor cycles off for 3 reasons:
Evaporator has reached 40 F (clearly not the case here)
Engine rpm too low (it's about to stall)
Too much high side pressure (seems like that would be it)
You need to measure both pressures to diagnose. Or maybe the pressure is normal but the high pressure switch is triggerhappy.
trustdestruction trustdestruction is online now
Send a message via AIM to trustdestruction
i have the same problem, except my compressor's not new.
i tried doing the r134a conversion and it seemed to help a little but not enough.
__________________
Vote for Barack Obama if you care about our country!
Quote:
Originally Posted by ej6buddy View Post
there's a lot of idiots out there, and too many of them to point out, so whats the point? lol
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
