RE: Wierd noises!!
sounds like a ground loop..... make sure your amps are grounded at the same spot..... make sure it's a good clean contact... no paint ....... if that doesnt help try grounding the shields of your rca cables..... check the deck as well...... also make sure the power wire is run down the opposite side of the car then your rca lines....
hope this helps
__________________
96 civic..t25 turbo...FMIC
jdm sir ll swap..stage 2 ACT clutch
OBX LSD...hondata s300
AEM wide band...ACL race main and rod bearings
JE forged pistons and rings
Eagle H-beam rods...cometic head gasket
GM 3bar map sensor..GM boost seloni
