Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 06-28-2008, 03:08 PM
CrunchyToast CrunchyToast is offline
My Garage
Default A couple fuse questions
Where would i be able to locate the specific fuse for the temperature gauge? also where can i find the wiring to check for the horn to work?
Sponsored Links
Old 06-28-2008, 03:23 PM
RonJ RonJ is offline
HCF Humble Servant
My Garage
Send a message via AIM to RonJ
Default RE: A couple fuse questions
If only the temp gauge doesn't work, start by disconnecting the temperature sending unit (located below and slightly forward of the distributor) connector and then grounding the single wire to the engine with the key turned to ON. The temperature gauge reading should rise (disconnect before it reaches max temp). If the temp reading doesn't rise, the problem is the gauge itself. If the temp reading rises, then the sending unit is bad.
Here's the circuit diagram for the horn:
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/zerothread/1901557
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 07-06-2008, 12:28 PM
My Garage
So for the temp gauge, I disconnected it and stuck a wire inside the connector (so I didn't have to take it and re-strip it) and touched the wire to the top of the engine, turned the key to 'On' and the gauge did not move. Now, I'm assuming I must replace the gauge and hope they aren't too much.
As for the horn I have yet to do this.
Old 07-06-2008, 12:36 PM
HCF Humble Servant
My Garage
Yeah, if the wire was making good electrical contact with the terminal of the sending unit connector and a metallic engine part, then the gauge itself is most likely bad. Another possibility is a bad wire running between the sending unit and temperature gauge, though this seems less likely if the wire looks fine.
__________________
Old 07-06-2008, 04:27 PM
mk378 mk378 is online now
My Garage
The gauge is powered from the same circuit that runs the gas gauge and the speedometer (if it is a 1992 or later model with electronic speedometer). So if those still work but the temperature doesn't go up to hot when you ground out the wire, it has to be the gauge itself or the wiring.
On the horn, start by testing the horn itself by jumping it to the battery. They get corroded and quit. If the fuse, button, and cable reel are good you should hear the relay clicking under the dash when you press the button.
Old 07-06-2008, 06:04 PM
My Garage
Quote:
ORIGINAL: mk378
The gauge is powered from the same circuit that runs the gas gauge and the speedometer (if it is a 1992 or later model with electronic speedometer).Â* So if those still work but the temperature doesn't go up to hot when you ground out the wire, it has to be the gauge itself or the wiring.
On the horn, start by testing the horn itself by jumping it to the battery.Â* They get corroded and quit.Â* If the fuse, button, and cable reel are good you should hear the relay clicking under the dash when you press the button.
All other gauges work. I have a few dead lights in the dash (ex: door ajar) but other than that, everything works except the temp.
When I press the horn button on the steering wheel I do hear a clicking sound. I believe I hear it coming from right where I push it, meaning right behind the button or somewhere near there.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
