Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 06-29-2008, 09:55 AM
Adam34996 Adam34996 is offline
Default Front Driver side Wheel noise
Just started recently. I only notice it at low speeds, when I go over bumps. It probably is happening at high speeds, but I just cant hear it. The sound is a grinding/thud sound coming from the front left wheel, happens when the wheel is strait, left, or right. Loud over bumps. Took the wheel off, looked for anything hanging, saw nothing, everything looked intact.
Could it be wheel bearing? Sounds like from my research, that seems to be the most likley problem. Could it be anything else? Anyone got an idea of an repair estimate? Would appreciate some of your guyses inputs
Sponsored Links
Old 06-29-2008, 10:00 AM
RonJ RonJ is offline
Default RE: Front Driver side Wheel noise
Remove the wheel again and carefully inspect the strut (shock absorber, spring, and associated suspension) for loose components or damage.
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/zerothread/1901557
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
