Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 07-02-2008, 12:19 AM
Ruester Ruester is offline
Default '91 Civic Fuel Filter question...
Is it possible to clean a clogged fuelfilter, or do you always have to replace it?
I bought a new fuel filter about a year ago and I recently ran the car out of gas (fuel gage crapped out) so now it's clogged again, can I clean it out?
Thanks all,
Aza[&o]
__________________
My ride is ugly
Sponsored Links
Old 07-02-2008, 02:39 AM
saiguanas saiguanas is offline
Default RE: '91 Civic Fuel Filter question...
You won't clean it effectively. Besides, you're supposed to change it every 12 months anyway. It's due. They're only $13.
Old 07-02-2008, 04:16 AM
mk378 mk378 is offline
There's a pre-filter on the inlet of the pump in the tank. That should be changed too as it seems you have a lot of crud in the tank.
Old 07-02-2008, 11:38 AM
That means I have to drop the tank though, right? - I always have to pay someone because I don't have a garage. Just street parking here.
Thanks guys,
Aza
__________________
My ride is ugly
Old 07-02-2008, 12:04 PM
No, you can take the bottom cushion of the back seat out and service the pump by reaching the top of the tank thru an access panel.
Old 07-02-2008, 03:41 PM
Really?! That's so cool! Thanks! I'll check it out.
__________________
My ride is ugly
Old 07-16-2008, 10:32 PM
Well, I tried getting t6he back seat cushion off, but couldn't figure out how to do that. In the front part of the seat cushion, underneath it is held on by two u-shaped pins in slots that I couldn't release. Does someone know how to remove the rear seat cushion?
__________________
My ride is ugly
Old 07-16-2008, 10:50 PM
trustdestruction trustdestruction is offline
Send a message via AIM to trustdestruction
Default RE: '
if it's the same as a 92-00 civic, there's a bolt behind the drivers side rear seat's seatbelt buckle. it holds another one of those U shaped brackets to the frame.
__________________
Vote for Barack Obama if you care about our country!
Default RE: '
once you unbolt this, you should be able to lift the back of the seat cushion up so that the 2 other U shaped pins act like a hinge. then remove the seat.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
