RE: more questions involving setup
If the main speakers are all coaxial speakers(2,3,or 4 way-all in one speakers) run those channels full.
Sub Low pass..
Input raises the voltage on the incoming signal. DO NOT turn this all the way up........
I usually try turning the stereo up around 3/4 or so and then adjust the input level to be Loud. Does the amp have a light or something that will show it clipping? You don't want to PEAK the amp out all the time. I'm no pro by any means. But I did sleep in a Holiday Inn Express once.........
