I have a b16a2 with the stock tranny. when im on the highway, crusiing at what my speedo says is about 65-70mph, im revving at 5-5500rpm.... talk about losing gas. The tranny also has a bad third gear. it clunks everytime i shift into it.
So im deciding between beating the tranny till it breaks and get a gsr tranny or just get a longer final gear and fix third.
How much would each way run me? and which would be better?
i dont think it should be reven that high.......... most motor/tranny are designed to run about 3K rpm at about 65mph. sounds to me like your tranny is about to take a dive because its not shifting into OD or 4th one or the other...
Huh? Its called a manual transmision. They are all designed to rev differently. Hes talking about driving in 5th gear. Op,you are revving WAY too high. At 65-70 you should be seeing 3500-4000 rpms tops. Do you have like 14" wheels with crazy low profile tires? I actually have the same problem. Same motor and tranny. Im thinking about going to an LS tranny with long gears for better mileage and lower revs.
ya my 94 SOHC 5speed manual still did 65mph at 2.5-2.75k RPMs
not positive about DOHC motors but youd think the gearing would be pretty similar.... sounds like somethings not shifting properly for reven that high....
Well shorter gearing is much better for going fast so dx trannys and the like will slow you down but at this point in time people are starting to want mpg's over speeed.
ya im all for MPG over HP!!!!!
i got high HP, good MPG, and a just BFVehicle.LOL
66impala, civic, and a bus.LMFAO also a work truck.
which do i drive daily... of course the MPG one! LOL gas aint geting no cheaper. [8D]
