lol. It's a valid question. Depending on what you're looking for powerwise/what RPM it spools at there are various turbo sizes you would want. I can't answer that question as I don't know that specific information about which turbos produce what power and when they spool. I can tell you though that bigger turbos produce more power at 8psi compared to a smaller turbo at 8psi. However, the bigger the turbo, the longer the spool lag. Do some searching to figure out which turbo would best suit your needs.
__________________ Vote for Barack Obama if you care about our country!
Quote:
Originally Posted by ej6buddy
there's a lot of idiots out there, and too many of them to point out, so whats the point? lol
It says for integra but same principles apply, depending on the turbo manifold, and turbo size there are different fitting arrangements you'll need to figure out. Some are easier than others, some require getting rid of A/C, power steering, and even cutting off some metal on the tranny.
