Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 07-08-2008, 04:24 PM
glloyd1 glloyd1 is offline
My Garage
Default Starters keep going bad
hello All,
I have had to replace the starter in my 2000 4dr Civic DX 3 times in the last two months. The first time I replaced it, the second time I replaced it and the battery, the last time which was yesterday I replaced it and returned the car home until I figure out why the starter keeps dying or I sell the car. I did buy the starters at Advance Auto but that doesn't explain two in a row failing after only a month. I believe something is killing them. Anyway I am really tired of getting stranded by the same problem and would appreciate any expert knowledge that can be bestowed upon my humble being.
Thanks
__________________
2000 Honda Civic 4dr DX
Sponsored Links
Old 07-08-2008, 04:33 PM
RonJ RonJ is offline
HCF Humble Servant
My Garage
Send a message via AIM to RonJ
Default RE: Starters keep going bad
Are you having any other engine problems that would make cranking the engine difficult?
When the starter dies, are any fuses being blown?
Is the starter solenoid or starter motor dying?
Edit: Added diagram below.
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/zerothread/1901557
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 07-08-2008, 05:27 PM
My Garage
I haven't noticed any problems or changes in the performance of the vehicle I drive it about 50 miles a day and usually at unsafe speeds on the DC beltway.
I also haven't noticed any electrical problems related to fuses being blown, although ever since I have owned the car the radio dies after playing it real loud for 30 minutes or so requiring me to turn it off and back on.
Unfortunately I don't have the equipment to test whether it is the solenoid or the motor, I suppose it is time to invest in a multimeter and ohm meter. I always thought my car was a DX and after looking up the VIN just now discovered it is an SE. Maybe I got the wrong starters, I will check that now.
__________________
Old 07-08-2008, 05:34 PM
HCF Humble Servant
My Garage
Quote:
ORIGINAL: glloyd1
(A reasonable multimeter is not very expensive. Check you local Walmart or Sears Hardware store.)
Do you mean EX:
__________________
Old 07-08-2008, 05:53 PM
My Garage
my vin is: 2hgej6619yh548321
carfax says it is Civic/SE
http://www.carfax.com/cfm/check_orde...PopUpStatus=0#
The grade code is 1 which doesn't look like an option according to the graphic you posted. I will start pulling fuses out tomorrow to see if any are blown.
__________________
Old 07-08-2008, 06:06 PM
HCF Humble Servant
My Garage
Correction: Actually, you have a U.S. 2000 model made in Canada.
Possibly some variant of the DX model (code 19 vs 2x?) with the D16Y7 engine and an automatic transmission:
For comparison with Canadian models:
__________________
Old 07-08-2008, 07:27 PM
babyivan's Avatar
babyivan babyivan is offline
My Garage
It could be possible that you installed it wrong, causing the starter gear to not sync up with the flywheel teeth correctly and have to work harder to turn the engine over.......
Im merely guessing here, but I know that was possible on the older american cars that required shims to line the starter up right.
__________________
1996 EX coupe 5 speed....
amber tails..... FTW!!
Old 07-08-2008, 07:34 PM
HCF Humble Servant
My Garage
Quote:
ORIGINAL: babyivan
Well, starter removal and installation looks pretty straightforward, but here are the instructions anyway:
__________________
Old 07-08-2008, 07:40 PM
My Garage
The first one I installed did have a very different sound than the original however the second one sounded exactly like the original and I heard it the moment it died, it cranked for about half a second before quitting. None of the starter gears looked worn at all and there was no oil or water or any other fluid dripping on them. Short of it being the wrong part I am not sure how I could have done it wrong.
I went and checked that the #31 fuse is actually a 7.5 amp fuse and it is and appears to not have any kind of heat damage.
__________________
Old 07-08-2008, 07:48 PM
HCF Humble Servant
My Garage
How long has each starter lasted after installation?
Are you sure the starter itself fails? Was each "bad" starter bench tested? Maybe your electrical connections are loose, damaged, or corroded or the ground is faulty.
Edit: Another possibility is that the ignition switch is faulty, the battery is low, or the battery terminals are corroded.
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
