07-12-2008, 07:54 PM
clusters
will a manual cluster that has the speedmeter,rpm,gas,and temp plug up in a automatic car that has just the speedmeter,temp, and gas gauges or do u have to modify it ,its a 1997 honda civic
07-12-2008, 07:56 PM
HCF Sol'er
My Garage
RE: clusters
it'll work. all 96-98 (maybe 99-00 too) clusters are interchangeable and will work. you'll just have useless automatic gear indicators.
07-13-2008, 12:04 PM
Window Lickin' Moderator
My Garage
RE: clusters
Quote:
ORIGINAL: trustdestruction
it's the other way around. Unless I mis-read, he's putting a manual cluster into an auto, so he wouldn't have the gear indicators at all.
And it'll plug straight in. You'll just have an extra connector hanging off the harness for the gear indicator that'll have nothing to plug into.
__________________
-2001 Ford Mustang - The DD
-1978 Fiat X-1/9 - The Resto Project
-E36 M3 or bust-
07-13-2008, 12:18 PM
My Garage
RE: clusters
yes it'll work, and just to confirm, its all 96-00 that are interchanable, not just 96-98 and 99/00
__________________
07-14-2008, 02:40 PM
RE: clusters
thanks
07-14-2008, 04:08 PM
HCF Sol'er
My Garage
RE: clusters
Quote:
ORIGINAL: reaper2022
it's the other way around.Â* Unless I mis-read, he's putting a manual cluster into an auto, so he wouldn't have the gear indicators at all.
And it'll plug straight in.Â* You'll just have an extra connector hanging off the harness for the gear indicator that'll have nothing to plug into.
my bad, i misread it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
