Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 07-13-2008, 05:34 PM
nineteenninetynine nineteenninetynine is offline
My Garage
Default subwoofer problem
i was driving the other day and my subwoofer would pop in and out. so i turned the music off and you could hear a pop every so often so im guessing thats the power to the subwoofer thats going off and on...
any help???
__________________
1999 ex dc headers greddy tic cat-back aem cai Custom 17" konig rims
short shifter black jdm headlights tinted taillights si front end
Sponsored Links
Old 07-13-2008, 05:53 PM
ShaTownCivic's Avatar
ShaTownCivic ShaTownCivic is offline
My Garage
Send a message via AIM to ShaTownCivic
Default RE: subwoofer problem
Go over all of your wiring. Make sure you don't have a short somewhere. When your subwooferis on does it sound good? Might be blown. I say just check your wiring.
__________________
97 del sol turbo 99 civic hatch
Old 07-13-2008, 06:04 PM
Sigracer10's Avatar
Sigracer10 Sigracer10 is offline
My Garage
unfortunately theres not just one thing that we could tell you is the problem. It could be a variety of things such as a bad ground connection on the amp, a bad speaker wire connection betweenthe sub and amp, a bad power wire connection at the amp or the battery, or even a bad set of RCAs.
What I would do first is go over evey connection of the whole system and check that everything is securly and properly connected. If that still doesn't try running a new temprorary set of RCA cables and see if that helps.
__________________
Old 07-13-2008, 06:10 PM
addiction2bass addiction2bass is offline
My Garage
ya its a huge could be anything deal....
i had a inline fuse before that had a bad joint that would oddly enough loose conection turning my amplifier off from power not geting to the amp. could also be a loose speaker conection on the amp, on the sub box, on the inside of the box/ on the sub itself.
could also be a small wire sliver from the wire that shifts over and touches another terminal shorting the amplifier.
__________________
Old 07-13-2008, 06:22 PM
My Garage
alright thanks ill check everything then get back to you guys.
__________________
Old 07-14-2008, 11:23 PM
cyberx32's Avatar
cyberx32 cyberx32 is offline
My Garage
Its almost always the ground, so make sure its grounded right, you might even have to ground the headunit
__________________
http://www.cardomain.com/ride/2390477/2
I was wondering if the forum had a special section for real engines???
roto: F u.... the drama thread sucks donkey hoofs....let's all be gay in this thread.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
