Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 07-13-2008, 07:13 PM
Old Skool EF Old Skool EF is offline
Default The EF wont start :(
Whats up guys? a couple of buddys Of mine and I put a new trans in my EF and after we were all done and hooked everything back up we went to start the bitch it wouldnt start. you can hear the starter but theres nothing. we let the batter charge for a lil bit and we still didnt have enything. so the we check the grounds and they all looked fine. the ground that goes from the Valve cover to the front of the car started to smoke. imstumped b.c it started b4 we swaped trannys. Thanks -Phil
__________________
91 SI Slamed on GSR Blades
Sponsored Links
Old 07-13-2008, 07:45 PM
trustdestruction trustdestruction is offline
Send a message via AIM to trustdestruction
Default RE: The EF wont start :(
i'm not sure if it would cause that to happen, but do you have the ground from the tranny to the frame hooked up?
__________________
Vote for Barack Obama if you care about our country!
Old 07-13-2008, 07:50 PM
RonJ RonJ is offline
On later models, there are grounds on the thermostat housing and the transmission. Carefully double check those grounds.
Are you saying that the starter is not cranking the engine or that the starter is cranking but not the engine is not firing up? If the latter is true, do you have spark and is the fuel pump priming?
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/zerothread/1901557
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 07-13-2008, 07:55 PM
mk378 mk378 is offline
The big wire from battery (-) to the frame and then on to the transmission is not working. The starter current is trying to pass thru the little wire on the valve cover, which should not happen.
Old 07-13-2008, 09:58 PM
jpnolan's Avatar
jpnolan jpnolan is offline
If a wire is smoking you need larger gauge wire replace the wire and you might have it running.
Old 07-14-2008, 09:00 PM
Whats up Guys? thanks for all the help. i looked at all the grounds. Im starting to think that my starter is bad. im goin to take it out and take it in to get tested 2marro. hopefully thats what it is. Thanks - Phil
__________________
Old 07-17-2008, 07:07 PM
Shes Back. i had to get a new starter. The old one was shoot. Takin it to the Track 2marro night to see if theres a Difference between that old LS tranny and my new B-16 Trans. thanks guys for all the help.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
