Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 07-15-2008, 08:49 PM
Hoopty Hoopty is offline
My Garage
Default 95 Civic engin question
I just bought a 95 Civic 4dr LX with 250,000 miles. It is leaking oil pretty bad, so my question is. Is it worth trying to get the leak fixed( not sure yet were it is leaking from) or should I replace the motor? How many hours would it take an experienced mechanic to swap in a different motor?
Sponsored Links
Old 07-15-2008, 08:52 PM
RonJ RonJ is offline
HCF Humble Servant
My Garage
Send a message via AIM to RonJ
Default RE: 95 Civic engin question
First locate the source of the oil leak(s), for example from the oil pan, valve cover, rear or front main seal, distributor, VTEC solenoid, etc.
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/showthread.php?t=878010
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 07-15-2008, 09:07 PM
My Garage
It is on the side with the distributor and rear main.
Old 07-15-2008, 09:10 PM
HCF Humble Servant
My Garage
Well a distributor leak would likely be easy to fix, whereas the rear main seal would require more work. Try to figure which. Do you have VTEC?
__________________
Old 07-17-2008, 06:53 PM
My Garage
looks like the rear main or the trans. Is it worth it to try to fix the leak since the car has 250K miles?
Old 07-17-2008, 06:57 PM
HCF Humble Servant
My Garage
Are you also losing transmission fluid? If not, then the rear seal is leaking. If the engine runs fine otherwise, I would seriously consider just replacing the seal rather than the whole engine. Just my opinion.
__________________
Old 07-18-2008, 10:29 PM
My Garage
RonJ, What part of TX are you in, anywhere around Austin?
Old 07-18-2008, 10:46 PM
HCF Humble Servant
My Garage
No, I live in the Houston area.
__________________
Old 09-03-2008, 07:38 PM
My Garage
So I finally got around to having it looked at and it is the rear main. Is it worth trying to fix if the car has 250K miles on it. He said it would be around $700-900 to fix it and put a new cluth in while the tranny is out. How much could I buy a used engine for? 95 1.6l.
Old 09-03-2008, 10:11 PM
mk378 mk378 is offline
My Garage
How bad does it leak? You may be money ahead to just keep putting oil in until it needs a new clutch, then have the seal done at the same time. That price also seems kind of high for a routine clutch/seal job.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
