and to let you know, most nitrous systems are setup so that they activate at wide open throttle, not by pushing a button. and nitrous is the easiest way to get 120hp. you don't want nitrous though, so for 120HP get turbo and an engine build.
if you mean not a 120hp gain but rather to get up to 120hp, the easiest way to do this is a mini-me swap. that is putting a d16z6 head on your d15b7 block, and using a d16z6 ECU.
Well what I was wanting was to have a good clean reliable car to drive that still got good mpg with a little more horses cuz the thing is slow as hell.
Well what I was wanting was to have a good clean reliable car to drive that still got good mpg with a little more horses cuz the thing is slow as hell.Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â *Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*Â*
from your original post, are you trying to get to 120hp, or trying to gain 120hp?
do the headswap, but use the 96-00 head, from a d16y8, along with the intake manifold, then do a good intake and exhaust, and youll be around 130-135 at the flywheel. not fast, but a lot quicker.
__________________
