Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 07-16-2008, 02:26 PM
bfusmc bfusmc is offline
My Garage
Default Not starting problem
i have a 93 del sol. one day i went to start my car it just kept cranking over and over i had fuel i had spark so i jumped it it started right up so it was wierd casue it was cranking but i bought a new battery. put it in runs fine for couple weeks then today had to jump it again . why does it crank yet when i jump it it starts right up. i am thinking alternator but could it be possible starter casue i can drive long distances and all acceseroies work while driving. im stumped . if any one has tips please post thanks. bill
Sponsored Links
Old 07-16-2008, 03:01 PM
RonJ RonJ is offline
HCF Humble Servant
My Garage
Send a message via AIM to RonJ
Default RE: Not starting problem
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/showthread.php?t=878010
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 07-16-2008, 06:59 PM
My Garage
yes put brand new plugs in and fuel was good. i think it might be a bad fuel regulator but this is a very wierd problem and very hard to diagnose since it is intermintent. and once it starts running when i jump start it or pop start it it runs fine and can drive for as long as it can go but sometimes if i stop it wont start again other times it will its very interminent very peculer
Old 07-16-2008, 07:13 PM
HCF Humble Servant
My Garage
So when the engine won't start, are you sure that the starter is actually cranking the engine?
How specifically are you testing for spark and fuel?
__________________
Old 07-16-2008, 07:18 PM
trustdestruction trustdestruction is offline
HCF Sol'er
My Garage
Send a message via AIM to trustdestruction
i had this problem on my civic. are your battery clamps loose on the battery posts? if they are, you might have a not-so-great connection and it will cause the car to sporadically not start. the jump starting works because you are clamping it to the battery clamps which is causing them to have a better connection. the solution to this is to tighten the battery clamps. if they are as tight as they'll go but the clamp is still loose on the post, you need to buy these lead battery post cover things. they go over the battery post and basically make the post wider so that you can tighten your clamps all the way. they sell these at auto parts stores for very cheap.
Old 07-16-2008, 07:42 PM
mundy5 mundy5 is offline
My Garage
consider getting your alternator tested as well. if you are losing battery voltage over time, it's potentially an alternator issue.
__________________
1998 Civic 4DR LX
2003 Ford Windstar LX
For civic service manuals: http://hondatech.info/downloads/Auto/Manuals/Civic/
Old 07-16-2008, 07:46 PM
HCF Humble Servant
My Garage
__________________
Old 07-17-2008, 06:27 PM
jermofrejected jermofrejected is offline
My Garage
only thing i can think of is if its cranking and sparking is maybe your fuel pump isnt working completely. my 89 was doin the same thing it was cranking my plugs were good but it wouldnt fire. but i had a l.e.d. under my carpet that told me fuelpump
Old 07-18-2008, 05:50 AM
mk378 mk378 is offline
My Garage
In every case of "cranks but won't start, but only sometimes", the main relay should be strongly considered.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
