RE: Need help with radio
yea go to any place that installs the brand radio you have and ask if they have any extra cages for that radio laying around. You need to unhook the radio, slide in the cage through the dash kit then bend some of the tabs on the cage back so it stays in place. Pull your wire harness and antenna back through the cage and connect the radio back up. When you slide the radio into the cage it should slide back and lock into place and sit flush for you.
__________________
-Kevin
