Go Back   HondaCivicForum.com > Your Ride > ECU Tuning & Fuel Management
Reply
Old 05-10-2005, 11:25 AM
Mikedg186 Mikedg186 is offline
Default Viper 5000 Alarm
Just bought a viper 5000 and i want to install it myself so does anyone know a site or something to show me step by step how to install an alarm?
i drive a 1995 honda civic CX HB
Sponsored Links
Old 05-10-2005, 09:54 PM
LEVIII LEVIII is offline
Default RE: Viper 5000 Alarm
Constant is a large white wire runing from the steering comumn to the fuse box.
Ignition is a large black/yellow running just below the constant.
Starter is white/black running with the constant.
Parking lights are red/black coming out of the top of the fuse box.
There is also a male blade in the fuse box that is p lights, I belive it is 3rd from the right but its been a long time since ive used that.
Door trigger is a large (mostly insulation) light green/red low in the driver kick, if you have cruise you may have to unbolt the bottom 10mm and move the silver box a little out of the way to acces it.
ground it to the kick after you scrape the paint away.
WOW, Ive done to many Hondas.
__________________
Buy your parts from........Speed6motorsports.com
pick 2: reliable, cheap, fast
Old 05-11-2005, 02:15 AM
thx lol
im sure theres more question i have when i start this :S
Old 05-11-2005, 10:36 AM
lemme know.
__________________
Old 05-14-2005, 08:37 PM
i dont think i found the right wire for the door trigger, everything else works except the door trigger and the parking lights, couldnt find the parking lights wire
pls help
Old 05-14-2005, 09:10 PM
Do you have cruise control?
__________________
Old 05-15-2005, 03:36 AM
nope, i have nothing power, no power windows, locks etc....
Old 05-15-2005, 10:08 AM
there should be a grey plug attached to the kick panel behind the carpet almost as far into the corner of the kick as you can go. The wire is in there. It is light green with a red stripe but is mostly insulation.
__________________
Old 05-15-2005, 12:09 PM
and the parking lights wire is a small red with black stripe(i think) from the fuse box, but there are 2 red with black stripe
does it matter which one?
Old 05-15-2005, 01:13 PM
yeah there is prob more than one of that color. Do you have a test light?
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
