Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 07-21-2008, 12:36 PM
dabflyboy dabflyboy is offline
My Garage
Default A/C "whooping" noise???
alrighty folks, for the life of me i can't figure this one out. i keep getting this strange "whooping" noise from my 2003 honda civic EX, but it only seems to happen when the A/C is on, and the car is typically at idle. my wife described it as if hearing a police siren being turned on only once and then back off again. it seems its random, but when it starts up it happens frequently, about every 5 minutes or so....maybe. any ideas?
Sponsored Links
Old 07-21-2008, 01:47 PM
mk378 mk378 is offline
My Garage
Default RE: A/C "whooping" noise???
If it's rather loud, probably the belt slipping. Check the belt and tighten or replace if needed.
Old 08-18-2008, 07:44 PM
My Garage
ok so i did some experimenting and it seems the only time the noise appears is when the car is at idle. the new thing i found was that it happens ONLY when the compressor kicks on. i guess typically when the A/C is on and the car is at idle, the compressor kicks on and off every minute or two. when it kicks on, the "whooping" noise appears.
Old 08-19-2008, 05:05 PM
SilverSedan SilverSedan is offline
My Garage
shot in the dark, but I'm thinking something with your AC clutch is screwy...maybe its not grabbing properly...OR it could be the belt. check the condition of your belt, and if its shot, replace it. Check the belt tension too, should be a little play, but not much.
__________________
97 Sedan D16Y7 5spd...stock
Old 09-01-2008, 12:50 PM
My Garage
man, i wish you guys could actually hear this, it really sounds like a police siren. also, i put the car in park the last time i heard it start to do this and opened the hood. the noise is definitely louder in the car than under the hood. odd...
Old 09-01-2008, 03:58 PM
RonJ RonJ is offline
HCF Humble Servant
My Garage
Send a message via AIM to RonJ
Post a sound recording. Did you tighten and/or replace the A/C belt? Could be that the compressor bearing is shot.
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/showthread.php?t=878010
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 09-02-2008, 12:06 PM
My Garage
How loud is this noise? If playing the radio at normal volume will cover it up, it is probably just the sound of normal refrigerant flow through the expansion valve.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
