Go Back   HondaCivicForum.com > General Automotive > General Tech Help
Reply
Old 07-22-2008, 07:47 AM
gas_miser gas_miser is offline
My Garage
Default 95 civic TPS Sensor issue
Can you replace a TPS sensor on a d16z6? I have a dead spot in my pedal and I am almost positive that the TPS is bad. The car has a ton of miles on it. I checked with honda and they said it is attached to the throttle body and you have to replace the entire assembly. Any help is greatly appreciated.
Sponsored Links
Old 07-22-2008, 07:52 AM
My Garage
Default RE: 95 civic TPS Sensor issue
oh, the car is a 1995 civic ex with the d16z6 as well. I have replaced the timing belt, idler pulley, cam/crank seals, plugs, wires, air filter, fuel filter, fuel pump, sending unit, and all belts. I also checked the ignition timing. The car is getting 36 mpg, but it hits a dead spot about half pedal every time no matter how you accelerate. Its in the same spot. I can accelerate all the way to the upper rpms if i accelerate slowly. I just wanted to add this information in.
Old 07-22-2008, 08:28 AM
mk378 mk378 is offline
My Garage
No CEL though? You can test the sensor with a voltmeter to be sure it is bad.
Officially the sensor is not replaced seperately, but if you can find one it can be. Drill out the breakaway screws and put the new one on with regular screws. The sensor must be calibrated when replaced onto the throttle body.
Old 07-22-2008, 08:49 AM
My Garage
no...there is no CEL light on and no codes have been set. I found a couple new ones on line. how do you calibrate the new one?
Old 07-22-2008, 08:55 AM
My Garage
what should the voltage read on the sensor?
Old 07-22-2008, 09:51 AM
RonJ RonJ is offline
HCF Humble Servant
My Garage
Send a message via AIM to RonJ
About 0.5V with throttle fully closed and about 4.5V with WOT.
Are you sure the ignition timing is not off?
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/showthread.php?t=878010
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 07-22-2008, 10:43 AM
My Garage
The car has had the same issue since i brought it home. We have replaced the timing belt and everything listed above. We have also checked the ignition timing several times. We even retarted and advanced the timing. It still has the exact same issue now as it did before. I do know that it acts up in the exact spot in the pedal every time.
Old 07-22-2008, 11:09 AM
My Garage
Measure voltage from the center wire to ground with the sensor connected, key on, but engine not running. The voltage should increase smoothly from 0.5 to 4.5 as you move the throttle slowly from closed to wide open.
To calibrate a new one, loosen the screws and rotate the sensor so you get 0.5 volts with the throttle closed.
Old 07-22-2008, 11:18 AM
My Garage
thank you mk378. does anyone recommend a aftermarket one. I wasnt sure if one brand was better than the other.
Old 07-22-2008, 10:48 PM
turkeysandwich turkeysandwich is offline
My Garage
I would highly recommend buying an oem sensor from http://www.inlinefour.com/il4oemretps.html . You can also find one at http://www.omnipowerusa.com/ but I bought one from there and it ended up going bad, it could have been something I did or just a bad sensor though.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
