Go Back   HondaCivicForum.com > General Automotive > General Civic Talk
Reply
Old 07-23-2008, 05:05 PM
trustdestruction trustdestruction is offline
HCF Sol'er
My Garage
Send a message via AIM to trustdestruction
Default Header Gasket Problems
I keep blowing header gaskets. Im talking about the one between the 2 pieces of a 2 piece header. Tomorrow I plan on cutting out a new gasket out of this sheet of gasket material i have, and im going to put it on like normal.
I read that using High Temperature Silicone RTV or Copper High Temperature RTV on the gasket will help and prevent my gasket from blowing again.
My question is, which of the two previously mentioned materials will work better in protecting my gasket from blowing and help it make a better seal?
My guess is the copper.
Sponsored Links
Old 07-24-2008, 11:16 AM
HCF Sol'er
My Garage
Default RE: Header Gasket Problems
anyone? wanted to do this today so opinions would be great asap. otherwise i'm just gonna go get the copper and hope it's the better of the two.
Old 07-24-2008, 11:26 AM
omgftw omgftw is offline
My Garage
post are not working
dfgkidfjdsfgdsfg
Old 07-24-2008, 11:34 AM
RonJ RonJ is offline
HCF Humble Servant
My Garage
Send a message via AIM to RonJ
Trust, do you think the underlying problem is that the interface between the head and block is warped?
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/showthread.php?t=878010
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 07-24-2008, 12:17 PM
HCF Sol'er
My Garage
^^^ it's the gasket in between the two header pieces. i'm not sure if it's warped or not. i just got back from advance auto parts and i picked up the copper rtv, hopefully with it on the gasket i won't have another problem.
Old 07-24-2008, 08:46 PM
HCF Sol'er
My Garage
well i replaced the gasket today. i think i figured out the problem. my catalytic converter has a spin flange, and it wasn't adjusted right, which was putting strain on the header's 2-piece joint. so i took the downpipe portion of the header completely off, and bolted it to the header with the new gasket and the copper rtv, and torqued the bolts down nice and tight. then i connected the cat, using the spin flange to line up the flanges so there would be as little strain on the header's joint as possible. i waited about an hour, then took it for a short drive. i got home, let it cool off, and re-torqued the bolts. so far so good, i hope it holds up this time.
Old 07-25-2008, 01:42 PM
Live_4it Live_4it is offline
My Garage
Oh man I've been going through the same ****. Don't buy the gasket material!. Tried the same thing worked for a couple days then bam blows. I have a megan racing header and the reason i'm pretty sure is because the two pieces aren't machined perfectly flat.
__________________
Old 07-25-2008, 01:44 PM
My Garage
I've been calling megan for 3 months and they still don't have gaskets. What I did that finally worked was I bought an OEM acura/honda gasket, lined it up with the blown gasket from the header.
__________________
Old 07-25-2008, 01:45 PM
My Garage
Then used a dremel to widen the flange holes and remake where the bolt holes go. Been working now for a month, but I know in about a month or two this one will go but atleast the package comes with two. If you need more info pm me.
__________________
Old 07-25-2008, 05:19 PM
HCF Sol'er
My Garage
well what kind of gasket material are you using? im using some that seems like pretty much the same material as a megan gasket, i just had to cut it myself. it still seems to be holding up well. that copper rtv might be helping a lot.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
