turbo at low boost in high compression engine
what is the deal with turbo charging a high compression engine?
is it possible if you use low boost pressure?
is is better since you have more low end torque?
what problems can you encounter with tuning?
i have a d16y8
bored 30 over,ported and polished,11:1 compression,with je pistons and skat h beam rods,
crower camshaft stage 1,crower valve springs and retainers,cyliner brace,shaved and balanced crank,calico bearing,arp studs.
plus all fuel updgrades (i.e. walbro fuel pump,aem fuel rail,venom injectors,holley fuel pressure regulator,and aem fuel filter)
__________________
I TRY TO BE NICE TO ONE PERSON EVERY DAY
TODAY IS NOT YOUR DAY
AND TOMMAROW IS NOT LOOKING GOOD EITHER!!!
