what should i get turbo or super charger
Old May 19, 2005 | 11:24 AM
  #21
97CivicEX's Avatar
Default RE: what should i get turbo or super charger
ORIGINAL: polo708
My s/c is a roots style and I am currently running water/methanol injection. It's basically the same as an I/C but does the job by injecting a water methanol mix intot he intake stream which absorbs alot of the heat out of the air.
Yup, I am running just water injection on my truck for the same reason. However WI and intercoolers do have their differences. An intercooler does a great job of cooling the charged are before entering the combustion chamber and will net a more dense oxygen content. While the WI takes up some space within the chamber that would otherwise have been filled with oxygen. The WI does have other benefits that the Intercooler doesn't have as well, it keeps EGTs under control a little better and it keeps your combustion chamber a little cleaner(kind of like a steam bath). It also helps with a more efficient burn wich lowers NOX emissions. The main thing is it "effectively" increases your octane rating because it aids pre-detonation to help with engine pinging. There might be other differences, but those are the ones that stand out the most.
Old May 19, 2005 | 11:28 AM
  #22
97CivicEX's Avatar
I run a smaller pulley on my truck and I think I saw a smaller pulley for the jackson SC I was looking at. You can always have it fab-ed up. However expect higher EGTs, going into boost quicker(more gas consumption), and possibly exceeding SC rpm ratings. I would say WI and/or intercooler is a must. And not recommended for stock internals.
Old May 19, 2005 | 11:29 AM
  #23
97CivicEX's Avatar
ORIGINAL: javierdagreat
how much internal work i am looking at
I would say keep it under 6psi of boost and you should be fine, unless you drive with your foot to the floor all the time. If that is not enough power for you and you want to increase boost levels, internal work should be considered.
Remmy
Mar 13, 2007 12:55 AM
Civic03
Aug 17, 2005 02:56 PM
Civic03
14
Jul 29, 2005 07:07 PM
javierdagreat
May 18, 2005 07:02 PM
Super Mario
13
Oct 31, 2004 12:28 AM
