Go Back   HondaCivicForum.com > Misc. > Motorsports/Racing > Street n Strip
Reply
Old 05-20-2005, 10:15 AM
INJENalltheway INJENalltheway is offline
Default Shift points
Alright tell me if this is good for racing. I shift from first to second at 29-30 mph then from second to third i shift at 59 the from third to fourth i shift at 80 then i cant max out fourth gear until 112. Is that good.
Sponsored Links
Old 05-20-2005, 12:06 PM
Patrick Patrick is offline
Administrator
Default RE: Shift points
you know, you could get a very inexpensive tachometer at most parts stores, and it would be safer.
__________________
Old 05-20-2005, 03:36 PM
hondabboy hondabboy is offline
you wanna shift before the redline to stay in the high rpms (for v-tec). dont push the car to its redline limit because you'll lose pick up and time.
__________________
"pucutum, pacatap, pucutum, pacatap!!!"
Old 05-27-2005, 12:36 AM
se7ensectoolate se7ensectoolate is offline
Step 1) Buy tachometer.
Step 2) Dyno car.
Step 3) Figure out where the horsepower peak is at the top end.
Step 4) Shift at that peak in horsepower.
If your car makes its peak horsepower at 6300 RPM and the redline is at 6500 RPM, there's no point to shift any higher than 6300 RPM. Fairly simple.
Old 05-27-2005, 01:09 AM
blackeyes blackeyes is offline
bounce it off the revlimiter just to know for sure
__________________
vtec is a way of life
Old 05-27-2005, 08:12 AM
Forty04 Forty04 is offline
Administrator
Not to thread jack, but does anyone know the stock peak hp shift point for a 99 Civic Ex?
__________________
Don't PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
Old 05-27-2005, 05:45 PM
neon3kgt neon3kgt is offline
Send a message via AIM to neon3kgt
somewhere i read an article about when to shift, it said that dont bother knowing where your higher power point is, because no matter what you benitfit from shifting at redline (but not hitting rev limiter) they tested it and it showed that no matter what you should get as many rpms from your engine as possible.
Old 05-27-2005, 11:21 PM
clutchjunkie clutchjunkie is offline
forty04: according to chiltons, the horsepower peak for our EX's is 6800.
__________________
1995 Nissan 300ZX Twin Turbo, emerald green 2-seater
fully loaded, but stock like a mutha f###a
Old 05-28-2005, 12:11 AM
sacicons sacicons is offline
actually, if your power does drop off, you should see what rpm you would be at after the shift. if you lose say, 15hp from 6300 to 6800 redline, but shifting at 6300 will put you where you are down 20 from what you have at redline, then you should wrap it to the redline because you have more power there than where you would be if you shifted. and ive seen a stock focus being tested that shaved a few tenths by shortshifting by a couple hundred rpm. thats just really poorly engineered gear ratios though. but for the original Q, get a tach, and shift at redline.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 05-28-2005, 12:38 PM
Nail I3unny Nail I3unny is offline
Send a message via AIM to Nail I3unny
heres an idea...get a tach with a shift light
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
