Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 08-14-2004, 08:32 PM
OrangeCivic OrangeCivic is offline
Default What can I do??
I have a d15b7 in my hatch and am looking to just do what I can with it. anything just looking for ideas I want to get the most out of it. so far I have done the intake headers and pipe but now I want to start doing things that will give me a little more. anything would help thanx.
Sponsored Links
Old 08-14-2004, 09:51 PM
sacicons sacicons is offline
Default RE: What can I do??
i had the same dilema with my 95 dx coupe. if youre not looking to spend the money on a motor swap or FI, then look into a mini-me vtec head swap. you should be able to get everything you need for under 500 bucks. another option is to swap in the whole sohc vtec swap, with a d16z6, all you need is the motor with all attached accessories, your tranny will work but the z6 tranny has better gearing, and the ecu, then run a couple of wires. you should be able to find everything with a yahoo or google search
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 08-19-2004, 05:43 AM
polo708 polo708 is offline
Send a message via AIM to polo708
you could always upgrade the ECU, grounding kit, stuff like that. Have you gotten into suspension yet??
__________________
-brian
Old 08-25-2004, 06:03 PM
Yes everything is done but the engine. Should have done it the other way around.[sm=badidea.gif]
Old 08-26-2004, 04:37 AM
no, i was just gonna suggest that if you didnt already have it.
__________________
-brian
Old 08-26-2004, 01:03 PM
NTX NTX is offline
Quote:
ORIGINAL: sacicons
if youre not looking to spend the money on a motor swap or FI, then look into a mini-me vtec head swap. another option is to swap in the whole sohc vtec swap
Those are your best bets. If possible, do the dohc swap.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 08-26-2004, 02:42 PM
yeah, the immediate power gains are great with the DOHC, but the real worth of the b-series is in the potential power of the motors, you can build the hell out of a d16z6 and run the crap out of gsr swapped civics, but then they drop in a set of cams and a thin head gasket and theyll walk away from you. the best way to do it is to set up the suspension and brakes first, to handle the newfound power. i would have gone more in depth with my suspension and little stuff first, but a spun rod bearing required a new engine sooner than i planned.
__________________
Quote:
ORIGINAL: Forty04
Old 08-29-2004, 07:10 PM
92SiR2Hatch 92SiR2Hatch is offline
Save your money and get a motor swap. That is the best bang for the buck. The best power adder for a sohc is Nos or Turbo.
__________________
The little hatch that could
Old 09-03-2004, 04:39 PM
So if I was was going to do the swap what engine would be the simplest swap?
Old 09-03-2004, 09:09 PM
b16a2, preferably jdm (technically called the b16a 2nd gen) or obd1 gsr. any post 94 b-series would be pretty easy. the obd1 would be easier though (and cheaper).
__________________
Quote:
ORIGINAL: Forty04
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
