RE: 97 honda civic egine swap
if you get an obd1 engine you can get a jumper harness, you will need the SI rear motor monut, and hopefully you get the shift linkage and ecu with the motor. you will need new axels as well, the place i got mine had all the stiff there to buy with it, it was a little more than ebay but i got all the right stiff. email i will give you the website i got it from. no need for him to get free advretising on this forum. other than the stuff i listed it was pretty easy to do. i recomend that unless you know the car it is coming out of to change the timing belt, water pump, alternator, and clutch as it is alot easier to it outside the car than inside. i made that mistake because i wanted it in faster, and it took alot more time fixing it later. my friend is a mechanic and we did it in my garage in a weekend. although it seems pretty simple in thought if he wasn't helping me i would have done it wrong and i think of myself as pretty mechanically inclined. now it runs like a dream. good luck.
__________________
Vinyl Graphics, car magnets, window advertising, I can make it. Email me at eric_meyer@charter.net
