EG Swaps 1992-1995 Civics
1.5 engine swap
Old Jun 9, 2005 | 09:45 AM
Martinogdenbsx's Avatar
Default RE: 1.5 engine swap
where can i get them?
Old Jun 9, 2005 | 10:53 AM
Cappelle's Avatar
Make sure it is a B seris engine before u get to carryed away becuase the D16z6 has 125 hp and is a 1.6... just.... just so that when you go to do it you know what happening
Old Jun 9, 2005 | 05:37 PM
i will check with them,cheers,i will be in touch soon
Old Jun 10, 2005 | 03:55 AM
right i have found out the exact model engine number and it is a d16z1 which is a 1.6 V-Tec
The guy reckons i won't need to change any of the ransmission or anything and all i will need is the wiring???
Does anyone happen to know the BHP for it???
Cheers
Chris
Old Jun 10, 2005 | 06:20 AM
well??
Old Jun 10, 2005 | 12:32 PM
Pete's Avatar
ORIGINAL: Martinogdenbsx
what is a tranny???The engine will come with an ecu,my question is is it a major job or is it relatively simple???
i sure hope if YOU are installing this u have a buddy who has done a swap before. It is not an easy task i hear. Make sure u have a car to drive around as this swap is taking place.....ur going to run into little problems that will set u back a bit. The D16 motor has 125 HP @ 6600 Rpms.
Old Jun 10, 2005 | 01:31 PM
my dad is installing it i just phoned honda dealers they told me there is a d16z1 it is 6500 revs,122bhp,1.6 litre vtec,fuel injected
Old Jun 10, 2005 | 01:41 PM
Cappelle's Avatar
Yeah swap D seires engines is pretty easy....but if u never had vtec before u well need ECU and may have to wire the Vtec selinoid in...
According to the site i have been using for engine info i got this on the D16z1
D15Z1 1.5 16VSOHC VTEC-E PGM-FI 1493 92hp@5500rpm 97tq@4500rpm 92-95 Civic VX
I know u put D16z1.. but as far as i can tell there is only a d15z1
Old Jun 10, 2005 | 04:16 PM
nah theere is a 1.6 definetly,will i be able to use the ecu he provides me with which is from that engine????Is it easy to wire the solenoid in???
Old Jun 10, 2005 | 10:27 PM
Cappelle's Avatar
Um it's not to bad and u my not even need to i didn't have to when i swaped to vtec... if u do well it's not real easy i don't think it's bad though... but i never did it.... if the engine is coming with a ECU then it will work just fine.. i was trying to find the DIY for wiring the vtec for u but i can't find it again.... there will be one on the net if u need it. But don't get to worryed u might not even need to wire it up... but then again you might
