Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > EG Swaps
Reply
Old 06-07-2005, 04:01 AM
Martinogdenbsx Martinogdenbsx is offline
Default 1.5 engine swap
Hi
I have a 1.5 SOHC and i want to swap to a 1.6 esi,i phoned the person i would be getting the engine from and they said it was a BA..7 i think???it is 125 BHP
Would it be a straight swap with my 1.5lsi he is providing me with the ecu and wiring loom?
Thanks
Chris
Sponsored Links
Old 06-08-2005, 02:55 PM
315 Customs's Avatar
315 Customs 315 Customs is offline
Send a message via AIM to 315 Customs
Default RE: 1.5 engine swap
nope, you'll need motor mounts for a b series motor
hasport.com
__________________
-Kevin
Old 06-08-2005, 03:02 PM
is that it????
Old 06-08-2005, 06:13 PM
Roto's Avatar
Roto Roto is offline
HCF Village Idiot
if you're getting a B16 to replace your SOHC you'll need a B-seriel tranny(should be with the engine) and according ECU plus other small parts.
__________________
1. I'm never wrong.
2. If I'm wrong refer to rule 1
Old 06-09-2005, 02:21 AM
what is a tranny???The engine will come with an ecu,my question is is it a major job or is it relatively simple???
Old 06-09-2005, 07:47 AM
tranny is short for transmission, for the most part, no SOHC tranny will bolt to a DOHC motor.
You'll need the wiring for the B16, the motor mounts, ecu, possibly axles, I'm not sure for the EG civics on axles. Other then that you should be good to go.
Consider replace the clutch, throw out bearing, timing belt, water pump, alternator, and starter while you have the motor out of the cart before dropping it in so you have no worries down the road.
__________________
-Kevin
Old 06-09-2005, 08:06 AM
cool,it comes with wiring and ecu and mounts so it is only the transmission i have to check?
Old 06-09-2005, 08:45 AM
yea but is it only coming with the orginal mounts? The mounts you need are custom fabercated (sp) mounts to make the motor bolt onto your mounts
HASport.com
__________________
-Kevin
Old 06-09-2005, 09:32 AM
ah no they are the mounts the engine comes with?at least i assume so as it is from a salvage place,
Old 06-09-2005, 09:50 AM
yeah your going to need the motor mounts that are custom made for your car to bolt in a B series motor
__________________
-Kevin
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
