Go Back   HondaCivicForum.com > Your Ride > Header, Intake, & Exhaust
Reply
Old 06-08-2005, 07:18 PM
young gun young gun is offline
Default 1.6 header fit 1.5?
hey i have a 95 civic DX and i recently picked up a DC sports 4-2-1 one peice header ceramic coated for $50 at a swap meet. it is used but looks in good condition. the guy i bought it off of said it came off a 1.6L civic. i know that the header flanges are the same. there is a lil bracket that bolts to the tranny i belive that i don't think it looks right and also the placement of the O2 sensor is way off(down right before cat.) but the stock one is right on the header before the down pipe and i was wondering if anyone knew if i need an adapter for the it to make the O2 wire longer or if this header will not work at all. im gonna keep looking else where on the net for more info but i thought that i should also check with you guys cause some one might know more about this than i do. thanks for any info
Sponsored Links
Old 06-08-2005, 07:20 PM
Default RE: 1.6 header fit 1.5?
i just wanted to add it is a coupe if that will make anydiffrence
Old 06-08-2005, 08:56 PM
Pete Pete is offline
Send a message via Yahoo to Pete
just use sodder some more wire and extend it so u can put the o2 sensor where it belongs. It should work.
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Old 06-10-2005, 01:20 PM
hndanut1 hndanut1 is offline
i thought of that too but my only concern is that might mess up the resistance in the wiring throwing the O2 sensor off and make it not read right.
Old 06-10-2005, 01:25 PM
hmm maybe replace the o2 sensor with one from a 1.5.....maybe it will be long enough. I dont kno that soddering more wire will mess with the ohms to give it a bad signal. I would extend the wire if it were me. Just make sure u do a good job with it.
__________________
Old 06-10-2005, 01:28 PM
hey sorry about that i accidently used my friends name hondanut1. it was accually me also another thing my friend pointed out was there is a lot of heat in that area and might cause any solder to melt
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
