Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 06-08-2005, 10:32 PM
ballplaya4eva07 ballplaya4eva07 is offline
Default turbo d16
im thinking about getting a turbo for my d16. I know i should get new pistons, rods, and a camshaft. Is there any other internals that i should get? Also i think i might get the hondata s200. Is that good for a turbo car? What are some other little things i might need along with a turbo kit?
Sponsored Links
Old 06-08-2005, 11:13 PM
AnakinKenobe AnakinKenobe is offline
Send a message via AIM to AnakinKenobe Send a message via Yahoo to AnakinKenobe
Default RE: turbo d16
get the AEM managment system and get a block guard, remember to do you head up nice, springs retainers, valves, 3 angle valve job and some porting, its all about air flow, turbo timer, maybe an apexi AVCR for a good boost controller, hmm thats all i would want to start but that is costing some money there.. also sleeve your block and put a high performance oil pump and water pump too.....
__________________
Hold her tight, had her last nite lol haha ....
Old 06-09-2005, 12:14 AM
D16z6 D16z6 is offline
You should be fine with all your stock internal if you run 6psi.
__________________
A
Old 06-09-2005, 02:11 AM
Pete Pete is offline
Send a message via Yahoo to Pete
Quote:
ORIGINAL: HondaCivica
[sm=exactly.gif]
Im guessing this is ur daily driver. If it is u dont wanna run over 6PSI because it will mess with ur cards reliability.
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Old 06-10-2005, 10:04 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
what about 7psi would that still be safe
__________________
cylinder head guru!
Non Vtec power
Old 06-10-2005, 10:13 PM
sacicons sacicons is offline
intercooled i would say thats the limit. for a reliable ride anyway.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 06-11-2005, 12:21 AM
yeah it is gonna be intercooled and the whole fuel system is upgraded....so should be a pretty decent daily driver
__________________
cylinder head guru!
Non Vtec power
Old 06-11-2005, 12:23 AM
boost controller
cryo2 system on the front mount
etc......
__________________
cylinder head guru!
Non Vtec power
Old 06-11-2005, 12:51 AM
finalimpact finalimpact is offline
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
my d16 let loose at 13psi. i highly recommend a build before going that high[8D] main concern is tuning, find someone who knows what there doing.
__________________
Old 06-11-2005, 12:57 AM
ehh, I wouldnt rely on that cryo thing for upping the boost though. you wont have it turned on all the time. good for short bursts though. i saw a dyno on the NX Ntercooler, and it pushed almost 50 horses on an SC G35, going from around 450 to over 500. not too bad for not shooting any into the motor.
__________________
Quote:
ORIGINAL: Forty04
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
