Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 06-15-2005, 05:55 PM
adnan_u7 adnan_u7 is offline
Default 05 CIVIC - Installing A System
Hi, i just got my new 05 Civic (comes with standard radio):
http://us.autos1.yimg.com/img.autos....12_346x270.jpg
something like the pic above.
I've got a JBL GT4 series 1000watt sub and a An Alpine M350 (760 watt amp). Im planning on changing the head unit soon, but for the time being would i be able to install the amp and sub, and conenct them up to the standard radio already in the civic?
Im an absolute beginner, anyone got any ideas/guides on how to do so? How do i run the wires from the boot to the head unit (do i need to rip off the side panels and pass them behind them?? this wont damage nething will it??). And how would i be able to get wires to the head unit?? coz i dont see any simple way of being able to simply pull it out to plug the correect wires into it.. etc..
Any help would be much appreciated.
Cheers,
Adnan
[IMG]local://upfiles/3842/02D74E298F0544F297E0BBE55DC03821.jpg[/IMG]
Old 06-15-2005, 06:36 PM
Street Sniper Street Sniper is offline
Default RE: 05 CIVIC - Installing A System
You don't need to run anything to the headunit. You will need a Hi-Lo signal converter. Basically what that does is convert a high signal (speaker wire) to a low signal (RCA output). Just tap into your rear speakers for the signal.
As far as the rest, you need to run about 8 gauge power wire from the battery and find something that is switched 12v (meaning it comes on with the key) to run to the remote turn on of the amp. Then find a good solid ground to the chassis adn scrape away any paint from it. Try to keep your ground as short as possible.
Run the wires behind the kick panels and then under the carpet along the door jamb.
Hope that helps.
__________________
Tuned by G-Tech... Powered by YooHoo.
Quote:
...there's more than one way to skin the horsepower cat.
Old 06-15-2005, 08:09 PM
Pete Pete is offline
Send a message via Yahoo to Pete
Quote:
ORIGINAL: Street Sniper
Do it right. Use 4 Gauge wire. 760watts is going to be starved thru 8 gauge wire. Go 4 gauge. Trust me. DCA and REmmy will back me up.
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Old 06-15-2005, 08:14 PM
4 gauge is cool. You won't get any argument from me. I just meant at least 8.
__________________
Old 06-16-2005, 06:58 AM
cheers for the help guys..... but as i said, im a total beginner and half that stuff just means nothin to me... sorry if this is wastin ur time or a bit tedious for you, but as i said, any help si better than nothing so is much appreciated.
ur syain basically find the wires that run to the rear speakers... hook these up to the amp (and then all i need to do is hook the amp up to the battery)? Does this cut off the rear speakers? Or do i have to connect them to the amp as i would with the subwoofer?? Are you sure this won't affect my rear speakers in terms of quality etc..
And whats all the 8 gauge, 4 gauge stuff???? No Idea... sorry guys.. lol
Thanks 4 the help tho
Old 06-16-2005, 07:02 AM
oh 4got to mention... where can i get a Hi-Lo signal covnerter from and how much are they??
Old 06-16-2005, 06:43 PM
K.... bit more clued up now after spednin quite a while on google! lol..
yep.. so i know how to tap in to the speakers... and im gonna change the amp. Im gettin a Sony XM-D500X amp that gives 250 Watt RMS x 1 (this should be perfect for my sub..... coz thats 250 RMS)... is that right? ne1....
and i've found somehwere i can get a Hi/Lo converter... but whats all this abotu 4 gauge and 8 gauge... and how do i ground the amp??
Old 06-16-2005, 07:22 PM
The gauge of wire is the size. The smaller the gauge, the bigger the wire. The higher the wattage rating of your amp, the more power it will draw from your battery and subsequently will need bigger power wire.
If you haven't bought your amp yet I suggest you get a class D mono block amp. They are specifically designed to run subs and it'll be a lot easier on the alternator.
Grounding means literally connecting it to the frame of the car. Pull your carpet up and find a spot on the body as close to where you are going to mount the amp as you can. Scrape the paint off to get to bare metal and then bolt/screw the ground wire to that spot. Careful you dont drill into something important. If you are worried about drilling/screwing, find an existing bolt. A good ground is important.
__________________
Old 06-16-2005, 10:13 PM
Quote:
ORIGINAL: adnan_u7
NOOOOOOOOOOOOO!
[sm=badidea.gif]
__________________
Old 06-17-2005, 03:31 AM
k... i get it now.. cheers...
why NOOOOOOOOOOOOOO??????
The XM-D500X looks like the perfect companion for my JBL GT4-12 Subwoofer. Its also a Class D Mono block amplifier too, n it takes High Level input i think (so i wouldn't need a Hi/Lo convertor... would i)
So.... street sniper.... what gauge wire would i need to use for that?? Im only going to be connecting the (250W RMS) subwoofer to that amp... thats all. Im gonna leave the factory fitted speakers... they should be okay for now.
What do you rekon?
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
