Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 06-20-2005, 01:27 AM
maachan513 maachan513 is offline
Default When did you changed your clutch?
Hi,
I'm second owner of this '90 Hatchback 1.5 litter engine with 4 speed transmission. I took me some getting used to on first roll when I got this car. The car I had before this had a lot more torque and run like a tank. Anyways the Civic accumlated more than 150000 miles. According to the maintenance record from the first owner, the clutch has not been changed since new. I was wondering how long the clutch would last. So the questions are: 1) At what mileage did you change your clutch?, 2) Where do you live? Flat land, mountains or hills? , 3) What kind of Civic do you drive? and 4) How do you drive? Oh I almost forget, 5) What type, brand of clutch did you change to?
I thank you in advance for your reply.
Sponsored Links
Old 06-20-2005, 02:01 AM
LEVIII LEVIII is offline
Default RE: When did you changed your clutch?
I changed the one in my 2000 Si at about 65k and I was pretty hard on it. I replaced it with an ACT 6 puck which Im not sure if I would recomment it or not. My DX had about 100k on it and I never replaced it and was pretty hard on it. My 94 Si has 160 and I am starting to notice some slight wear and have been thinking about exedy. Not to bad though considiering my girl drives it daily and its the car she laerned stick on. Id say it has about 10k left if I take it easy.
Now on my mitsu at 17k the cluth is making noise and I am currently saving up for and hoping it will hold long enough for the $1500.00 double plate clutch from exedy. Not to mention I am fairly lucky to have gotten the 17k out of it and I have been babing it like crazy.
__________________
Buy your parts from........Speed6motorsports.com
pick 2: reliable, cheap, fast
Old 06-20-2005, 02:03 AM
Oh yeah, I live in the valley in Cali with few hills but the 00 Si and the Mitsu did so some twisties once in while
__________________
Old 06-20-2005, 02:45 PM
Mad7s Mad7s is offline
Send a message via AIM to Mad7s
103K
__________________
Always one ear to reality and one to the music.
RISK!
Old 06-20-2005, 10:37 PM
Hi,
Thank you for your replies, guys. I hope mine will last more than 170K. With mileage I rack up, it will be this time next year. Since I am planning to replace mine myself while I must have means of transportation, I must be thinking of alternative transportation, now.
I would like to hear from more people.
Thanx
Old 06-20-2005, 10:42 PM
Pete Pete is offline
Send a message via Yahoo to Pete
Quote:
ORIGINAL: maachan513
um........honda makes a "4 on the floor?"
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Old 06-20-2005, 10:43 PM
sacicons sacicons is offline
i went just shy of 120k on the original. then on my first swap, it should have had about 45k on it when one of the springs broke loose, fell down inside, and locked the clutch plate to the flywheel. that sucked. now i only have a couple thousand on the new Exedy on the new motor, with no sogns of weakening. (as it should be)
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 06-20-2005, 10:47 PM
I'm lost as to your question Pcupo. Rephrase?
__________________
RISK!
Old 06-20-2005, 11:14 PM
yeah, they did back in the day. not since 90 or 91 though.
__________________
Quote:
ORIGINAL: Forty04
Old 06-21-2005, 01:25 AM
Quote:
ORIGINAL: Mad7s
old american muscle cars used to either have an automatic (3 speed i think) or a "4 On the Floor".........was a 4 speed manual gearbox. I just never knew honda made em too.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
