hasport makes mounts. you need axles (hasport), covert to obd1 if you get obd 1 motor. if obd2 covert motor to obd1 it is easier. i know you need the shift cables, and an accord or prelude shifter assembly. You need to dent the right hand lower frame rail for trans clearance, and dent the firewall for intake manifold clearance, any b series cai for an ef will work. look for an older copy of sport compact car for swap details. Go to
www.hasport.com www.boomslang.us for obd conversion and swap info/ parts lists
And it can handle if you put the right suspension and tires on it they got like 1.05 g on skidpad with it and it ran i think a 13.4 on a completely internally stock engine with cai exhaut and header
