RE: Painting Valve cover, Can i clean anything inside?
no, its not real easy, but it is free and should be done anyway. the valve stems get worn down slightly over time and so you adjust the rocker arm( which opens the valve) to push it down as far as it is supposed to. there is a small amount of space you have to leave, its around .007 of an inch, this leaves room for the valve and rocker arm to expand when it heats up. you can do it if you get a haynes manual and follow the instructions. make sure the engine is totally cold when you do it. some things you can do without reading the instructions, this is NOT one of them.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
