Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
From Trinidad........alternator
  Printable Version
Honda Civic >> Misc. >> HCF Regions >> Canada, Over Seas & Elsewhere >> From Trinidad........alternator Page: [1]
Login
Message << Older Topic   Newer Topic >>
From Trinidad........alternator - 7/24/2005 6:04:20 PM
Syberfraggle
Status: offline
Any suggestions on what kinda of checks..tests or servicing that can be carried out on and alternator for a 97 civic ex?
Post #: 1
RE: From Trinidad........alternator - 7/26/2005 11:42:14 PM
cdn86gt
Status: offline
Connect a Voltmeter to the "B" terminal on the alternator, under the boot, and a good ground. Start engine and hold rpm at 3000rpm with no load until rad fan starts, then go to idle. Now raise speed to 2000rpm and turn on the headlights. Is the voltage between 13.6 volts and 15.4volts. Turn on blower motor and rear window defogger, is voltage around 13volts. Load her right up, brake lights stereo,etc, is voltage less than 13 volts. If you can read the amperage at it is less than 60amps in this fully loaded condition then your alternator is most likely okay. If the amps are hi then you may have a bad alternator or other component in the system causing problems. Hope this helps.
_____________________________
Current Stable
96 Civic LX
86 GT Cobra
74 V8 Vega
(in reply to Syberfraggle)
Post #: 2
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic Forum >> Misc. >> HCF Regions >> Canada, Over Seas & Elsewhere
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7489
New Vendors
K&N Engineering, Inc.
